Carrying an Elan chassis on a roof rack?
PostPost by: Giff » Sat Oct 30, 2021 10:19 am
Quick one - plan to collect a chassis tomorrow - should weigh less than 40kg and have a roof rack rated at 75kg - sound bonkers or the safest thing in the world?
Thanks!
Giff
First Gear
First Gear
PostPost by: Spyder fan » Sat Oct 30, 2021 12:35 pm
It’s nearly 9 feet long and the part that will bear on the roof rack is quite narrow, but I don’t see why it can’t be securely ratchet strapped in place.
Put a couple of pumpkins on the turrets to make it look a seasonal ornament so the police leave you alone :mrgreen:
Kindest regards
Alan Thomas
Spyder fan
PostPost by: elanfan1 » Sat Oct 30, 2021 12:46 pm
A family member did exactly that from Peterborough to Cardiff. No issues at all,
PostPost by: Giff » Sat Oct 30, 2021 1:10 pm
Ok getting ready..
roof.jpg and
Giff
First Gear
First Gear
PostPost by: mbell » Sat Oct 30, 2021 1:18 pm
I did it with a plus 2 chassis from Oklahoma City to Austin (400 miles) with out issue.
It's not very heavy so don't need very strong roof bars to support the weight but you do need to strap it down well to something strong enough for the loads under turning and breaking hard to avoid it becoming a projectile if you have to stop/turn quickly.
There is some variability in roof rack needs depending on what vehicle you are using, how the rack mounts to it and what you can secure the chassis to.
As mentioned a vehicle with long roof is helpful so you can place the bars under the wider sections of the chassis.
I did it with a Volvo xc70 which has a very long roof and in built roof rails. So I could use simple/cheap cross bars and strap directly to the vehicle roof rails to secure it. Which gave strong mounting points and external mounting points to hold it on position better.
PostPost by: Spyder fan » Sat Oct 30, 2021 1:30 pm
Giff wrote:Ok getting ready..
Perfect :D
Kindest regards
Alan Thomas
Spyder fan
PostPost by: nmauduit » Sat Oct 30, 2021 2:00 pm
I've done it several times, also unloading single handedly with a blanket to protect the paint of the car, it's a bit heavy but is easy to tie or grab.
S4SE 36/8198
PostPost by: pharriso » Sat Oct 30, 2021 2:23 pm
I carried a Spyder chassis on the roof of a Fiesta back from Peterborough to Chelmsford Essex back in 1983...
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Giff » Sat Oct 30, 2021 2:53 pm
pharriso wrote:I carried a Spyder chassis on the roof of a Fiesta back from Peterborough to Chelmsford Essex back in 1983...
My parents took me to London when I was a kid in 1983, had the rear seats of the Mk1 Cortina Estate folded down so my sister and I could sleep as we drove overnight.
Not sure that was such a great idea!
Giff
First Gear
First Gear
PostPost by: Mazzini » Sat Oct 30, 2021 5:54 pm
No problem.
IMG_3169.jpeg and
PostPost by: elated » Sat Oct 30, 2021 8:40 pm
Been there, done that with a +2 chassis.
Simples there are negligible windage problems.
The secret is a minimum of 2 good quality ratchet straps well tightened then checked after 15-20 mins travel.
Bon chance
elated
PostPost by: Pjr » Sat Oct 30, 2021 9:23 pm
I have also carried a +2 subframe on the roof of a Volvo V70. No problem at all!
Pjr
First Gear
First Gear
PostPost by: Gordon Sauer » Sat Oct 30, 2021 11:09 pm
Fiat 128-no problem, Gordon
75EBE2EF-9C87-45FB-9788-6DDA72C3D599.jpeg and
Gordon Sauer
PostPost by: Giff » Sun Oct 31, 2021 12:04 pm
2hrs drive in torrential rain but no problems - thanks for the feedback!
roof2.jpg and
Giff
First Gear
First Gear
PostPost by: bigvalvehead » Sun Oct 31, 2021 2:46 pm
not a problem!
IMG_20211015_112839.jpg and
Dave Hughes
S2 26R
Elan DHC Sprint
bigvalvehead
Next
Users browsing this forum: brianworld and 45 guests
cron
