S3 side window frames
Good evening all,
After fitting my s3 side window frames I noticed the passenger door does not shut correctly because of the bulge in the frame caused by the bend in the L section plate holding the door lock. I guess the drivers side was cut and welded at the bulge, fits flush with the door edge and it shuts great. Is the bulge normal or has there been a bodge in the past?
I don't know how I am going to get around this problem. Unfortunately I have just had the frames chromed.........
Thanks in advance for any suggestions.
David
David
- davidj
my bet is that it was bent at some point while out of the car (was it rechromed?) then just bent back, which left the crease. I would take it out and hammer it back (under hard wood to protect the chrome, and onto a hardwood spacer so as not to go too far : you may want to measure how much of the protrusion you need away to restore proper shutting of the door, and not overdo it as the chrome may lift in the shrink area - if so, seal the split with lacquer/varnish)
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Good suggestion. Thanks. It was deformed before chroming and I thought it was caused by the bending process when first manufactured. Maybe I got the Friday afternoon production. However, it *may* have been made correctly and has been bent subsequently. I will carefully try straightening it. Fingers crossed I don't damage the chrome.
Ta.
Ta.
- davidj
Users browsing this forum: Mike133 and 15 guests
