Tenax studs
Ah yes, next question - how do you get your hand (or some other implement) behind or under the dash and through the nest of wiring to get the nut on the end of the Tenax stud that goes in the front wing in front of the A pillar on the driver's side? My Tenax stud rattled loose and fell off a while back, and while I have been able to get my hand in and under the dash to tighten up the loose nut on the stud on the passenger side, installing a new stud on the driver's side has got me beaten (so far). All helpful suggestions gratefully received (short of removing the dash first!) Thanks, Jonathan
Jonathan Greenwood
Wimborne, Dorset
Wimborne, Dorset
- jonnyg
As I found, it requires some ingenuity and dexterity. I had only recently reinstalled the crash pad and dashboard and was wondering why I'd left this job until now. I removed the small air vents from each side of the dash. I have a small torch that I was able lie on the shelf inside the wing and behind the dash so I could see what I was doing. Using some vaseline I stuck a nyloc nut on to the tip of my thumb and was able to work it into the space behind the wing. I could see both the thread on the tenax stud and the nut and was able to thread the stud on to the nut. I suffered some abrasions from the rough fibreglass and it took a few tries but job done!
- milton
