Window lubricant
I’m about to get my Plus 2 window frames back from the platers and will be rebuilding them with new channels/rubbers. I’m anticipating a high level of friction and the motors struggling to open & close the windows.
The obvious lubricants would be silicone or PTFE. What have others used and with what success?
- NYK
I fitted new ‘silent channel’ (from Sue Miller) to my replated Plus 2 frames and also cleaned and re-greased the motor gearboxes. Didn’t do anything to the motors themselves. Windows operate as quickly and smoothly as on a modern car.
I’m not an engineer, but lubricating the furry channels doesn’t sound like a good idea, certainly not necessary in my case.
- Lotusian
NYK,
I had a series one Elise the workshop manual recommended a lubricant called Krytox, which I believe is a perflouropolyester, for the window channels.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
I've just replaced the silent channel on my S3SE with a new silent channel from Sue Miller.
The motor is having a hell of a time. I tried using a silicon lube which helped, but the motor squeals with resentment when I raise the window.
Is there a difference in the opening between a S3 and a plus2?
I'm wondering if Sue sent me the in-correct silent channel product
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
- pcarew
