Carpet install- Plus 2
1 post
Hard to believe, but I'm nearly ready to put the new carpets into the car! I've read through a bunch of archived posts about it and the methods look pretty clear, but I do have a question about the fitment.
When I cleaned out the interiour, I went down to the fibreglass everywhere- all underlayments, felt pads, etc were removed and discarded. After that I covered most of the interiour with some insulation made of 3/16" thick closed-cell polyethylene foam with very thin aluminium foil facing on each side, stuck in place with 3M spray adhesive. It's non-absorbent, provides pretty good thermal insulation and a little bit of acoustic damping, although obviously not as much damping as a heavier material would.
The new carpets (sourced from DBE, might be the same ones available from other suspects) came with some 1/4" felt padding, which appears be all-synthetic stuff and cut to fit under the carpet pieces.
Since I've put the PE foam everywhere, should I still use the new felt pads, or might this make the fitment of the carpets a bit awkward in places?
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
1 post
