seat belts
PostPost by: George S L » Wed Dec 30, 2020 11:26 am
Hi has anyone fitted the securon inertia reel seat belts in a +2 not sure which way they should be fitted.
George
Elan+2
Mk2 Mx5
George S L
PostPost by: mbell » Wed Dec 30, 2020 2:38 pm
I have, 502/30 model I think. I had to make up new brackets to fit them. You could probably make some cutting up some right angle steel if you don't have a welder.
Attached photos.
IMG_20200622_092321_01_compress35.jpg and
Brackets
IMG_20200622_133356.jpg and
Belts fitted
PostPost by: George S L » Thu Dec 31, 2020 8:29 am
Looks a nice job, will have to brush up my welding skills.
George
Elan+2
Mk2 Mx5
George S L
PostPost by: geni » Thu Dec 31, 2020 10:20 am
and how are the links attached at the bottom? would like to know more about their choices. (during my last email I received a few replies) which could make me make a decision.
geni
PostPost by: mbell » Thu Dec 31, 2020 2:47 pm
They look better in the photo than they are. I own a welder but don't claim to be able to weld!
Key thing with brackets is to get the right length for the protrusion and angle the belt in a little. This allows the belt to be closer to the trim and it to run smoother as it pointing in the direction it's being pulled.
geni wrote:and how are the links attached at the bottom?
The brackets bolt to the car via (new) standard mounts, the sets belts are bolted to the bracket via a nut welded to the bracket.
The rest of the belts bolt in as per the originals, in to the chassis and sill belt mounts
