Windscreen tie rod.
PostPost by: davidj » Thu Nov 05, 2020 9:40 am
Good morning,
Please could someone do me a big favour and send me a pic of the area where the windscreen tie rod connects to the skuttle. Assembling my car, using the original fixing hole, the new rod is pushing back the crash pad and leaving a significant gap to the windscreen seal which looks crude. However, this may be normal. The car is a S3, but I guess this area was the same for all the later cars.
Ta,
David
PostPost by: USA64 » Thu Nov 05, 2020 12:55 pm
[quote]the new rod is pushing back the crash pad and leaving a significant gap to the windscreen seal [quote]
I think it's normal, albeit, "significant gap" is open to question.
We are supposed to be having fun, are we not?
USA64
PostPost by: davidj » Thu Nov 05, 2020 1:36 pm
Is this classed as normal or significant? :-) As I bought the car in bits and all that was left of the original rod was the washer and stud still fixed into the skuttle, I have no idea of the fit tolerance.
IMG_20201105_132531.jpg and
PostPost by: ericbushby » Thu Nov 05, 2020 3:10 pm
Something doesn`t look right to me.
On mine the tie rod does not push back the crash pad. It presses down on the top of it making a depression at that point.
The tie rod is a 5mm one from Sue Miller.
On yours, I cannot make out where it is fitted.
Hoping to help
Eric in Burnley
1967 S3SE DHC
DSCF0585.JPG and
DSCF0586.JPG and
PostPost by: davidj » Fri Nov 06, 2020 6:47 pm
Thanks Eric.
It is the original crashpad and very stiff, Heating it with a hot air gun made it more flexible and fit better around the (Sue Miller) tie rod.
PS. Hope all is well in Burnley!
PostPost by: ericbushby » Fri Nov 06, 2020 7:27 pm
Hi David,
I hope it helped.
All is well in Burnley, but now you have an advantage on me. you know or can find out where Burnley is.
Think pennine moors, small villages and the occasional manufacturing town.
Now where are you as there is no entry on your heading ?. Give us a clue, maybe just a continent or even a hemisphere.
Keep going with the car it is the best one of the range.
Eric in Burnley
PostPost by: davidj » Fri Nov 06, 2020 7:46 pm
Hi Eric. You obviously forget my memorable visit just before the (first) lockdown. Come over to see my progress on the s3 in Ilkley when we can get out and about again.
David
PostPost by: ericbushby » Fri Nov 06, 2020 11:42 pm
David, I forget everything, ask the wife, she will tell you. It comes with advancing age.
Someday we will meet at a show or something and I will looking forward to it, If I remember to turn up.
Eric
Users browsing this forum: jebracing and 29 guests
