RHD Firewall pattens for pedals and master cylinders
PostPost by: vstibbard » Sun Oct 25, 2020 8:01 am
Can anyone help with dimension or pattern for location of the holes for the standard pedal assembly and master cylinders please as I've a new shell which has not been drilled.
If no pattens, a set off from the inner tunnel and top of footwell to the inner left bolt hole will suffice, as I can level it and work out the rest.
My other shells are all 26R with the triple master set up and pedal box which is quite different
Vaughan
PostPost by: John Larkin » Sun Oct 25, 2020 10:31 am
Hi Vaughan,
I have sent three images to your message inbox.
John Larkin.
1967 S3SE FHC, 1974 Rover P6B, 1949 Lancia Aprilia
John Larkin
PostPost by: vstibbard » Sun Oct 25, 2020 12:00 pm
Thanks John, Iv'e just picked them up, and replied. I'll print them off and take them up to the shell tomorrow morning.
V
PostPost by: Elan45 » Sun Oct 25, 2020 4:37 pm
Vaughan,
I bought my 3rd Elan in 1984 and I was thrilled, since it had been converted to 26R spec by the original owner in the late 1960s. It left Cheshunt as a LHD S3 S/E. The original owner kept it LHD, but did everything he could to make it a true 26R, including the 3 remote reservoir master cylinders. It appears to me that they simply added a 3rd cylinder to the left of the original 2 and on the same center to center distance. Do you think they did they did it correctly? They did not fit a balance bar, but simply put a clevis pin through the 2 push rods of the MC's and the pedal arm. Must have had way too much rear brake bias. And no, I've never driven the car as it remains a project yet to commence.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: vstibbard » Sun Oct 25, 2020 9:34 pm
When you get to it, by changing the bore sizes I'm sure you could get it to work, you may need a bias valve as well which frankly is what the balance bar is achieving, at very least you would have two cylinders and some degree of failure margin.
The standard pedal box has the master cylinder at slightly different heights to I think allow for the larger reservoir and or alter the ratio of clutch v's brake.
PostPost by: baileyman » Mon Oct 26, 2020 12:50 pm
A pic of the penetrations but no measurements. John
http://i248.photobucket.com/albums/gg17 ... inebay.jpg
(Hope that works.)
baileyman
PostPost by: vstibbard » Mon Oct 26, 2020 9:17 pm
Thanks John, that will also help with some of the other holes as well. iv'e all I need now to complete the pedal box fitting today.
V
PostPost by: Famous Frank » Mon Nov 02, 2020 7:51 pm
Please forgive me for piggy backing, but I too will soon be mounting a new body on my frame. Is it possible to send the diagrams or dimensions also. Mine is RHD also and I'll be installing either a new TTR pedal assembly or the OEM Pedal assembly.
Many thanks to all,
Frank Filicicchia
[email protected]
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
PostPost by: vstibbard » Tue Nov 03, 2020 12:35 am
Hi Frank, I'll pop them on a PM to you, use them as approximate references as it comes down the shell's as well.
Does your TTR shell have the tab welded to the lattice to take the end of the road pedal box? None of my TTR shells had it.
If you'r fitting the balance bar pedal box, I can share the dimensions of mine, noting that it is an original 1965 assembly, and the newer ones look different.
V
Users browsing this forum: Elanman99, Fossilnz, jebracing and 35 guests
