Original engine mount dimensions
Hi all, I was wondering if anyone has, or can point me to, the original specs of a lh and rh
motor mount, for a Weber car? I have several sets, some used , and the dimensions are
all over the map. Even the middle plate with the two holes range from .120 to .190 in
thickness.
I have one set that I had to modify a new set so severely just to get them to work with the engine in
my original, unmolested frame. Also, maybe someone could verify my dimension of
14 1/2 inches between the frame's mounts top holes, center to center.
edit: further research shows the dimension of top frame mounts is 14 3/4", per the shop manual.
Hmmm, could affect motor mount dimensions.
thickness.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
