Wiring loom to door
NYK
Hope the photo (turn it 90° clockwise...) shows what you require i.e. the hole in the body where the door wiring enters the cabin.
The dimensions for mine are; height to hole centre above flat surface of the cill is 10". The hole centre is 1 3/4" in front of the glass fibre flange. The diameter is about 5/8" or just large enough to accept the steel wiring conduit and passes through both inner and outer skins.
Obviously it is important that this hole lines up with the larger hole in the front of the door!
Please ask if you require any further information and I will do my best to help.
Gary
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
1972 Elan +2 S130/5
2001 Elise S2
- Gazzerb
Gazzerb wrote:NYK
Gary
Thanks Gary, are the wires hidden behind the carpet or do they come through the carpet?
- NYK
NYK
As this part of my car was stripped out when I bought it, I am not certain how the wires should be routed. Would anticipate they turn vertically upwards under the carpet and felt. I don’t recall seeing any wires on other Plus 2s passing through the carpets.
Any other members able to help us please?
Gary
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
1972 Elan +2 S130/5
2001 Elise S2
- Gazzerb
Users browsing this forum: pdenton26 and 25 guests
