1972 Rear seat squabs
Hello,can anyone tell me ( or have a picture) of how the rear seat bases clip in.There is a hole in the centre of the seat base and this lines up with a hole in the body.thanks
72 Elan +2S 130/5
Put in the garage after a mot pass in 2012,trying to make it back out.(Almost there)
- Steve Brooks
Mine have a single self tapping screw, with a trim ring, through the lower front portion of the squab, into the vertical portion of the floor. Not sure if this is original, or added by a PO.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
My '70 had black plastic pin drive rivets with the steel pin in the center. I believe they are original. They work quite well until it's time to remove them.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
prezoom wrote:Mine have a single self tapping screw, with a trim ring, through the lower front portion of the squab, into the vertical portion of the floor. Not sure if this is original, or added by a PO.
This is how my car (73 S130/5 was, with fast nut on the outside. Might not be original thou as my interior has been redone.
When re fitting I used some longer screws to make it easier together everything back together.
- mbell
