Plus 2 Door Catch Won’t Shut
PostPost by: Robzildjian » Sat Apr 25, 2020 2:34 pm
0C9A95C5-EDBC-43AA-A796-D282E563C999.jpeg and
E718016C-9D67-44C0-8547-F4B95B4D1ADB.jpeg and
Catch
I’ve just removed the door panel on my plus 2 as the interior handle would allow the door to be opened. I assume that the rod has come out and it had indeed. So I’ve put it back in and now the door won’t shut as the latch mechanism hits the steel section on the door opening rather than latches round it. I’m surprised by this as I’ve not done much to cause it. Any advice as to how to get the door to close again. I’ve posted a couple of pics.
Robzildjian
PostPost by: Matt Elan » Sat Apr 25, 2020 3:29 pm
The latch on the door is in the closed position; it rotates around to open. Try rotating it upwards with a screwdriver while holding the door knob in - that should spring it back into the open position. Then when it hits the door latch on the B piller it rotates back round to lock in place.
Visit me on matthewvale.com
Matt Elan
PostPost by: oldelanman » Sat Apr 25, 2020 3:33 pm
The latch is in the closed position. Use a screwdriver to pull it open while operating the interior or exterior handle and it should then work normally.
Edit: beat me to it Matt :D
S4 DHC
PostPost by: Matt Elan » Sat Apr 25, 2020 3:36 pm
Ah - but you did get the picture in Oldelanman! :D
Matt Elan
PostPost by: Spyder fan » Sat Apr 25, 2020 3:37 pm
The door catch pictured is in the closed position, put a suitable sized screwdriver into the catch and press the outside door handle or pull the inside lever while moving the screwdriver to reset the latch into the open position
door-latch.jpg and
Kindest regards
Alan Thomas
Spyder fan
PostPost by: oldelanman » Sat Apr 25, 2020 3:39 pm
Well at least we all agree on what the problem is :wink:
S4 DHC
PostPost by: Spyder fan » Sat Apr 25, 2020 3:40 pm
THIS MUST BE A RECORD!!!
A member asks for advice and within minutes no fewer than 3 identical correct answers appear one after the other.
This is so refreshing compared with the usual mess of conflicting advice we get on here :lol:
Kindest regards
Alan Thomas
Spyder fan
PostPost by: Robzildjian » Sat Apr 25, 2020 3:49 pm
Spyder fan wrote:THIS MUST BE A RECORD!!!
That is a pretty consistent and rapid response, Alan, couldn’t agree more. Thanks all I will give it a try.
Robzildjian
PostPost by: Robzildjian » Sat Apr 25, 2020 4:07 pm
Well tried it...and...it worked like a dream. Problem solved - thanks all - and thanks Alan for the annotated photo.
By the way what keeps those door rods from coming out of the holes? Are there little round clips or something similar?
Robzildjian
PostPost by: oldelanman » Sat Apr 25, 2020 4:18 pm
Robzildjian wrote:By the way what keeps those door rods from coming out of the holes? Are there little round clips or something similar?
Yes. They are visible in your pic. If you are missing one it's probably in the bottom of your door :roll:
SJ036U0001.jpg and
S4 DHC
PostPost by: Robzildjian » Sat Apr 25, 2020 6:18 pm
Thanks Roger. Thought that’s what I needed.
Robzildjian
PostPost by: Robzildjian » Mon Apr 27, 2020 10:06 am
Good news I have the clip in one of my boxes of bits. Would I not also need the terracotta coloured plastic ring too? Ive marked up the photo to show what I mean.
Robzildjian
PostPost by: oldelanman » Mon Apr 27, 2020 10:53 am
Yes the plastic part is essential. It goes through the clip and the hole on the lever and the rod end passes through it, expanding the 2 "legs" and holding it in place. Finally rotating the metal part and clipping it onto the rod then locks the whole assembly together.
S4 DHC
PostPost by: Robzildjian » Mon Apr 27, 2020 11:00 am
oldelanman wrote:Yes the plastic part is essential. It goes through the clip and the hole on the lever and the rod end passes through it, expanding the 2 "legs" and holding it in place. Finally rotating the metal part and clipping it onto the rod then locks the whole assembly together.
Yes thought so. It is missing - are these available anywhere?
Robzildjian
PostPost by: oldelanman » Mon Apr 27, 2020 11:55 am
The plastic part is not supplied separately but the complete clip is widely available from all the usual Lotus parts suppliers :-
https://www.sjsportscars.com/parts-and- ... 6U0001.htm
https://paulmattysportscars.co.uk/produ ... -rod-clip/
Also Sue Miller will stock them I'm sure, a link to her catalogue can be found here:-
viewtopic.php?f=50&t=45991
Courtesy of Phil Harrison.
The clips can also be found on ebay but be aware that there are different sizes.
S4 DHC
Next
