Elan S4 RHD Pedal box area pattern
The area of the drivers side footwell which fixes the pedal box assembly to the front face of the body received a GRP repair, which when completed covered over all the existing holes for the master cylinders, steering rack and heater hose, unfortunately with no pattern or template made to help when being reinstated. Would anybody be able to supply either a pattern or perhaps a photograph with usable dimensions...?
Redhatman.
Redhatman.
- redhatman
Redhatman,
I see no one has replied with the information you need. My car is still in pieces, and I can tape a piece of paper or card on the engine side or the bulkhead and draw around the holes from the drivers side. On my vehicle, with a light in the engine bay I can see where the holes would for a left hand drive car.
Where are you?
I am in Lincolnshire UK.
Richard Hawkins
Where are you?
Richard Hawkins
- RichardHawkins
Hi Redhatman
Please see attachment, I made this rough copy of my S3 (rhd) bulkhead before carrying out similar repairs to yourself. I hope the attachment will print out on an A4 sheet so should be good to cut around the outline and stick it onto your bulkhead, please put it against your peddle box frame to make sure the copy is faithful before cutting any holes . I have run the oil pressure pipe in aeroquip pipework with a bulkhead fitting (Press).
- TrevorJones
