Elan S3 door weight
PostPost by: stevebroad » Sat Apr 11, 2020 8:51 pm
Is anyone in a position to weigh a complete S3/S4 door for me? Door, glass, frame, motor, furniture, etc.
Or does anyone already know the answer?
Thanks in advance.
PostPost by: elanner » Sun Apr 12, 2020 11:58 am
I have an empty door shell (don't we all? :-)). It weighs 11 lbs. Hopefully somebody else can report the frame, glass & motor weight.
Nick
PostPost by: Elan45 » Mon Apr 13, 2020 12:55 am
I'll give a couple of days for someone to respond w/ a complete door, before I try to help. The windows glass is still in the frames, and I can add the door handles window motor and interior panel (door card), and that should get you close. Do you want the aluminum kick plates or is yours the later carpet fitted door panel?
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: h20hamelan » Mon Apr 13, 2020 1:59 am
Window glass and frame, 13 Canadian Pounds
Do we still have a Queen?
Love your Mother
Earth
PostPost by: englishmaninwales » Mon Apr 13, 2020 1:47 pm
Ok here goes for the door components (door shell is on the car, so no weight)
Winder motor incl harness 1.3 kg
Ext door handle S3 type 0.3 kg
Door latch mechanism 0.36 kg
Interior door handle S3 type 0.08 kg
Interior door remote mechanism with push rod 0.3 kg
Winder motor retaining plate 0.32 kg
Aluminium kick plate 0.12 kg
Door card fully upholstered with leather S3 type 1.02 kg
Door frame S3 with integral pull handle, fully assembled with glass, drum, pulleys, cable 6.20kg
All fixings 0.12 kg
Total 10.12 kg or 22.26 lbs
Plus the door, weight posted above, 11 lbs makes a total 33.26 lbs.
1966 Elan S3 Coupe
1994 Caterham 7
