Can you tell me where this bracket goes please
- dash (lotus specific) bracket with wiring shroud,
- U bracket mid point
- plate/rubber weather strip
- ignition switch/steering lock.
I was then left with this bracket (in my same storage box) which I can’t identify
Any help much appreciated
- Chris-72sprint
Chris,
Looks like the bracket that fits on the steering column locating the locking steering ignition switch, assume your restoring a Sprint that will have this set up.
Alasdair.
1953 David Brown Cropmaster
1954 S1 Land Rover
1962 Elite S2
1966 Lotus Cortina MK1
1968 Elan S3 SS Coupe Sold.
1968 Austin J40
1969 Elan S4 SE DHC
1972 Elan Sprint
1967 Citroen DS21.
1954 S1 Land Rover
1962 Elite S2
1968 Austin J40
1969 Elan S4 SE DHC
1972 Elan Sprint
1967 Citroen DS21.
- Alasdair
Alasdair wrote:Chris,
Really? My Column was like this:
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
So that's interesting.... Cross posting the picture from the other thread:
The OP is missing the clamp to the steering lock.
Where do the bolts that go through the 2 holes perpendicular to the steering column go?
Anyone have a source for this bracket & clamp? - as I do not have one
Phil Harrison
Those two holes are to be at the top, (is your car RHD) the bolts locate to the bottom of dash aluminum stay and the steering assembly.
LHS have ignition on the left, RHS is on the right I recall.
Alasdair.
1954 S1 Land Rover
1962 Elite S2
1968 Austin J40
1969 Elan S4 SE DHC
1972 Elan Sprint
1967 Citroen DS21.
1954 S1 Land Rover
1962 Elite S2
1968 Austin J40
1969 Elan S4 SE DHC
1972 Elan Sprint
1967 Citroen DS21.
- Alasdair
Alasdair wrote:Those two holes are to be at the top, (is your car RHD) the bolts locate to the bottom of dash aluminum stay and the steering assembly.
You mean to the bottom of the main column bracket:
Instead of the bottom bracket?
My car is LHD
Phil Harrison
Thank you very much for your replies - I can now see where it fits.
I knew there must be some logic to it being in the box with the other column brackets
My next challenge is I can’t find the throttle linkage for the 2 Dellortos
- Chris-72sprint
Whoops - ignore last comment
Schoolboy error - had the left and right carbs the wrong way round when I laid them out on the table
- Chris-72sprint
Chris-72sprint wrote:Whoops - ignore last comment
Hey! You get to wear the velvet donkey's ears for a day- we've all been there... some of us more than others!
Pete.
http://www.petetaylor.org.uk
Pete.
