Sizing Helicoil inserts for the bonnet and headlight pods
I need to fix my bonnet bobbins, plus one headlight bobbin on my Plus 2. Thought I'd stick Helicoils in there, but what size do I need? I measure the bolt head as 7/16", 20 threads / inch, diameter .243"
Does this one look right? Hard to tell from the picture but it looks a bit big?
https://www.amazon.co.uk/V-Coil-16-inch ... B00EO4NYUQ
JonB - Coveted Fifth Gear
mbell said 1/4 20 coils: viewtopic.php?t=46122&f=51&start=0#p330463
Presume that's 1/4" 20 threads per inch?
JonB wrote:mbell said 1/4 20 coils: viewtopic.php?t=46122&f=51&start=0#p330463
Yes, that is just from memory, maybe it is 7/16"...
Maybe check the parts diagram to confirm the bolt size. The thread insert should match the bolt. So if it is 7/16"-20 that the insert size you should buy.
- mbell
I tried helicoils for the bonnet but they were too short, make sure you get them to the full depth of the thread in the bobbin. I ended up replacing the bobbins, a time consuming job.
- mikealdren
You can get Helicoils different lengths.
If the hole in the damaged Bobbin has worn ovale then you might need to use a Keyed Insert which are a larger outside dia. You may need to make a drilling plate to keep the tapping size Twist Drill central also.
Think twice and drill once
Sounds like you need a "Zeus Book" + Screw Pitch Gauge + Vernier Caliper
Good luck
Good luck
- alan.barker
7/16" is the bolt head across flats.
The thread size is 1/4" diameter x 20 tpi, which is 1/4" UNC not UNF.
RogerFrench - Fourth Gear
I'm not sure how well helicoils would last in the alloy the pods bobbins are made of if original (they are often replaced by steel equivalent on repro body parts) : I would use complete thread inserts like Timesert or similar, and glue them in place.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
For sure the keyed insert will be more durable as they will be hinge pivots. Plus the outside thread on keyed insert need only a standard Tap.
- alan.barker
Interestingly, 1/4-20 is also the standard thread for lampshade finials. Did someone at Lotus have a bit of a sense of humour?
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Just a longer term suggestion about determining thread sizes: next time you’re at the hardware store pick up a 1” long screw and nut in each thread size below, say 1/2”, fine and coarse, tag each, and keep in a bag in your shop. From then on you can immediately determine any thread’s size.
- awatkins
If you buy a Unified Tap and Die set it comes with a Screw Pitch Gauge. Not expensive.
- alan.barker
one quick word of caution : some jig (or possibly the pod itself) should be used to ensure the 2 threaded hinges are reasonably aligned for final installation in case some play has to be taken up, or there is a risk of high friction or binding in operation.
S4SE 36/8198
Rivnuts not a bad idea i like it but i still prefer stainless steel keyed inserts
- alan.barker
Users browsing this forum: No registered users and 41 guests
