Carpet How Much Do I Need?
I have an S4 FHC and hope to be replacing the carpet this summer.
I have found a supplier, in Australia, the carpet is one metre wide.
Has anyone done this job recently enough to remember how much carpet I need. Due to the distance, shipping and import charges, I want to avoid not having enough, but also do not want to waste money buying an excessive amount.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Don't forget to factor in which direction you want the pile to run, with the width and length.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
RichardHawkins wrote:I have an S4 FHC and hope to be replacing the carpet this summer.
Richard Hawkins
Why not use Sue Miller?, she stocks carpet & has sets ready cut I believe.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
I did mine years ago with cut pile, 8' wide. I used the old carpet to make paper patterns for cutting new sections. I used 12 square yards including covering the boot floor. That included ensuring the lay of the pile was the direction I wanted. I had less than a square yard in scraps. YMMV
Chris,
The supplier is All Car Carpets Montrose Victoria, which I think is a suburb of Melbourne.
Rob,
I did not realise that the carpet looks different when viewed from different directions. How much extra should I allow?
Phil,
Sue can no longer supply loop pile carpet, and to my surprise I cannot find a UK supplier.
StressCraxx,
Sounds like 12 square yards should do the job. 12 metres of one metre wide should be a safe equivalent.
Thanks everyone for the help,
Richard Hawkins
Rob,
Phil,
StressCraxx,
Richard Hawkins
- RichardHawkins
This UK trim supplier lists loop pile carpet.....
https://www.martrim.co.uk/car-trimming- ... carpet.php
Looks a bit thin though (5/32" ?) Anyone used it ?
S4 DHC
S4 DHC
- oldelanman
Roger,
Martrim list loop pile, but cannot get anymore, and what stock they have is not as was originally used.
Ricard Hawkins
Ricard Hawkins
- RichardHawkins
Hi Richard,
Oh well I thought it was too good to be true! Thanks for the update.
S4 DHC
S4 DHC
- oldelanman
Scott,
I have written to your auto trim, asking them if they can export to the UK, and if they can supply a sample.
Thanks for the advice,
Richard Hawkins
Richard Hawkins
- RichardHawkins
Hi Richard,
My car had a variety of carpets in it so I'm not sure what was original except it was looped. The auto trim carpet is a slightly shiny nylon with rows of loops that are visible but not well defined.
There was another manufacturer/supplier, Auto Custom Carpet, that had a similar product. Black 601 nylon loop carpet. They may have a distributor closer to you.
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
Scott,
Thanks for the suggestion, I have written to Auto Custom Carpets, and await their reply.
Richard Hawkins
Richard Hawkins
- RichardHawkins
May I add a few ideas to this specialist subject?
Idea #1 : Newton Commercial in Suffolk supply quite a lot of OE trim. Perhaps they could run up a carpet set ?They supply the correct boot Hardura finish: newtoncomm.co.uk. NC would be my first port of call (when I get closer to this stage) as recommended by Sue.
Idea # 2 : Fall back solutions (for my S1 1/2 project where the original floor material was a dark grey "elephant hide" plastic (not my cup of tea) I had in mind fitting a tough period correct type carpet similar to those fitted to the Porsche 356. I found a possible source with http://www.lakewell.com in Belgium.
BTW: I was also slightly surprised by the quantities given above. Is there a typo ?
I hope these ideas help.
- Frogelan
When i made some Carpets for my TVR 3000M . I bought some Vinyl from Martrim and made some Piping to sew along edges of Footwell Carpets. Makes a nice finishing touch. Easy to do on old Singer sewing machine using a Walking Foot
- alan.barker
