Rear view mirror type,
My +2 is in the 700?s build numbers and didn?t have a rear view mirror when I acquired it.
The head lining looks original and there is no sign that the RVM was ever attached to the roof as is common to a lot of later +2?s. I have always assumed it should have the suction type mirrors that were common in the sixties.
Can anyone tell me if I am correct and also tell me the make of such a mirror that would have been used then.
Many thanks,
Peter
Many thanks,
Peter
1968 +2 BRM
- Peter +2
I've been looking into this as well.
I've got an early plus 2 as well, but mine had a mirror that didn't look quite correct (and is sun damaged and the mirror backing is looking a bit crappy).
I've found this recently on eBay, but the price is far too rich for me.
https://www.ebay.co.uk/itm/Lotus-Elan-S3-Elan-2-FORD-ZODIAC-MK3-Original-NOS-Int-Mirror-NEW-1965-68/193146340962?hash=item2cf86b4662:g:n0UAAOSwBPRcM4sr
Interestingly my windscreen has evidence of an adhesive mirror being fitted at some point. I beleive the windscreen is original or at least period correct.
Elan +2 #0245
Exige S2 Supercharged
Elan +2 #0245
- Chrispy
The rear view mirror on the early Plus 2 is the same as the S3 Elan Coupe, being a Ford item from a Zephyr Mk3 of the period. They were screwed on to the roof through the headlining.
viewtopic.php?f=36&t=15023&start=
nmauduit wrote:jono wrote:...just like the one I have for sale
isn't it rather this kind (which I won't sell without the car...)?
But how is it fixed to the car?
My headlining shows no evidence to have having anything attached to it.
Curiouser and curiouser as they say.
Peter
1968 +2 BRM
- Peter +2
Peter,
I have a Wingard mirror which is shown below that might or might not interest you. This was sold to me by someone on the Forum who claimed it is a S2 mirror which I don't think it is!
The mirror is 143mm x 54mm. It is on a stalk which would place the centre of the mirror 105mm down from the mounting (2 elongated screw holes which are 30 min and 52mm apart.
I have now opted for a Lucas 608 which I bought on Ebay so I am happy to part with this one for a very modest sum (say 20 ?) to cover the postage in a box to you (or anyone who would like to buy it for that matter).
Please note that it has been "restored" and that it will need some TLC as it wobbles on the stalk!
Andrew
Andrew
- Frogelan
Peter +2 wrote:Bill / Chrispy
I hadn?t considered a stick on type, any chance of a picture Bill as the one mentioned on eBay looks like a screw on type.
Peter
Hmmm, having seen the photo showing a mirror screwed through the headlining I realise I was wrong above, I must have been thinking of one of the other cars that I've owned over the years or about the CB aerial which I had which definitely had two parts glued to the windscreen inside and out so that the glass acted as a capacitor coupling.
The one in my S3 Coupe is like the photos shown, screwed to a boss in the roof under the headlining.
I would think there's a good chance your car has had a new headlining at some time in the past 50 years or so Peter!
I have seen on two 1968 S4 coupes (one Fed and one UK) which I believe quite original, at least for that aspect (both had their original "confetti" headliners, a fabric that is only now reproduced, but not quite exactly as the original), that they are screwed on a smal piece of wood glued (glassed?) on the ceiling, like for sunvisors.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Elanintheforest wrote:I would think there's a good chance your car has had a new headlining at some time in the past 50 years or so Peter!
Yep, I am beginning to realise that my original thinking was wrong and that the RVM should attach to the roof.
Jon, I have sent you a pm and hopefully yours is still available.
Andrew, thanks again for your kind offer.
Thanks to everyone for their input in clearing up my misunderstanding.
Best
Peter
1968 +2 BRM
- Peter +2
