Radiator Fixing Brackets
Hello gentlemen. I have come across a very early S3 Elan. The radiator fixing brackets which look professional bolt to the top flat of the bonnet scoop. I have not seen this type before being used to the angle brackets that fix to the metal scoop support. Can anybody confirm that these brackets are the originals from the factory??
My thanks
Brian Buckland
My thanks
Brian Buckland
- elanman
By complete coincidence, I have just worked out how my radiator is attached and identified my S3 radiator brackets in the rusty pile of mangled metal I purchased. Picture attached of the refurbished upper brackets and remade lower ones. The lower one in the picture is for the RH side. They fit on the top of the two bonnet support scoops as can be seen on the picture posted by Craven.
I must have thought a hundred times "Why have holes been drilled on top of the scoops?"
David
David
- davidj
