Heated windscreen....
It does indeed Alan. See you at Birmingham.
- Robzildjian
I contacted Dan at Evans Motorsport regarding the +2 screens, his reply is below.
Hi Alan,
I am indeed, I have them in stock at the moment as the following?.
Elan +2 clear standard = ?180 + VAT (due 10 weeks)
Elan +2 clear heated = ?240 + VAT (in stock now)
Elan +2 Tinted heated = ?245 + VAT (in stock now)
Dan
Ricky Evans Motorsport Ltd
Unit 11, Roman Park
Claymore , Tame Valley Ind Est
Tamworth
Staffs
B77 5DQ
Tele 0044(0)1827283688
email [email protected]
Follow us on facebook
http://www.facebook.com/ricky.evans.motorsport
Kindest regards
Alan Thomas
Alan Thomas
I have bought heated windscreen for a TVR 1600M which i think is the same as a plus 2 elan from "UROGLAS".
- alan.barker
Uroglas were mentioned in this thread but the current website doesn't give any details...
viewtopic.php?f=36&t=19335
Brian.
Brian.
- ncm
If anyone is interested the US shipped price for the +2 heated screens above (Ricky Evans Motorsport) is as follows:
Clear and heated windscreen - Door to door (to Nebraska) 503 UK Pounds fully insured and shipped.
My guess is that this is DHL Express.
Nick
Nick
Nick Baxter
1970 Plus 2S (Federal)
1969 Plus 2 (UK) - sold
- nwbaxter66
Yes the wires are embedded in the lamination. I fitted a rear window version of this product and it must have adequately sized wiring and a relay to prevent a fire! The load is much higher than the original heated unit. I haven;t measured it but it must be in the region of 200watts/25ish amps. In addition it has a wider black edging which shows beyond the seal (at least on the rear window), much like a modern. This covers the edge of the headlining and is not visible from the inside of the car.
After 10 years it is showing sign of water ingress into the lamination (milkyness) in a small area, probably because the seal against water in the +2 rear window is so poor allowing water to be in contact with the laminated edges. Then again, my car has not been under cover for 10 years, so in typical use this is probably not a problem.
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Users browsing this forum: Quattro123 and 8 guests
