Under bonnet foam - how to stick?
Depends what sort of foam you have, i used Evo stick to put mine on but i know it melts some foam's, you could also use Spray on contact adhesive be be aware it tends to get everywhere if your not careful. If you do use contact adhesive of any sort test it on a spare bit of foam first to see if it melts.
Double sided tape is fine on the flat surfaces but doesn't stick very well to area's like the under side of the bonnet where it's rough grp.
Grizzly - Coveted Fifth Gear
No self adhesive on the stuff I bought from PM's. I used spray on carpet type glue (mainly because I already had a can) and that's been fine for years. A messy job though.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
I always use spray on carpet contact adhesive, masking off the surrounding area and applying it to both surfaces. I use panel wipe and a bit of sanding on the underside of the bonnet before applying. Never had an issue with any of our cars over many years - the foam deteriorates before the glue!
- nigelrbfurness
https://www.woolies-trim.co.uk/category/304/adhesive
Foam is light so gravity shouldn't come into it but if using felt the heat resistant glues are needed. The heat resistant aerosol looks a good bet for either. Easy to use too.
Derek UK
Derek UK
- derek uk
I'm considering the same thing so this is useful.
I was considering double sided carpet tape as it has more 'body' than standard ds tape.
I haven't checked my foam for reaction to contact adhesives.
Bought my foam locally - much cheaper than usual suspects.
- MarkDa
The other thing to look for is the life of the foam, not sure how you judge this but I've seen a lot of crumbling old foam over the years, the foam in the 'A' pillar of my +2S being a classic example.
- mikealdren
Just to return on this .... I found I had some strong tacky double sided tape in the garage, the sort of thing that you would perhaps use for carpets maybe. Seems to have done the job nicely for now.
Lots more question will follow as I work my way through the car!
Harry
Harry
- HJF
