Dash Bolts
PostPost by: 1969Plus2 » Tue Jul 02, 2019 2:27 pm
Does anyone have photos of where the upper most dash bolts on the left and right hand side screw in on a Plus 2?
I noticed that one of my dash bolts (left hand side on a left hand drive) was spinning in place and when I went to investigate it appears that it isn't screwed into anything and doesn't look like there is anything for it to screw into! Same thing on the passenger side.
1969Plus2
First Gear
First Gear
PostPost by: Gordon Sauer » Tue Jul 02, 2019 6:32 pm
Memory says they are not functional because I remember at one point mine backed out and I just put something on them to secure them for looks Gordon Sauer
Gordon Sauer
PostPost by: wotsisname » Tue Jul 02, 2019 10:22 pm
Hopefully you see the upper centre pair with bolts in. These are into threaded bobbins. On the RHS (andLHS) there,s just a hole in a flange.. this is a 68 +2.. the screws are same as the elan I think.
The PO had just used rawlplugs and mirror screws.. I will probably try to put a captive nut in. I expect it will squeak a bit if not tight
Adrian
img_20190702_231300171.jpg and
Dash, mounting, +2,68
1968 Elan plus 2 - project
2000 Elise S1 - Sold
wotsisname
PostPost by: 1969Plus2 » Tue Jul 02, 2019 10:26 pm
Strange, I don't seem to have those holes to bolt into...
1969Plus2
First Gear
First Gear
PostPost by: wotsisname » Tue Jul 02, 2019 10:44 pm
The flange remade, or just missing at that point ? Lighter.. but a bit less functional..
wotsisname
PostPost by: Gordon Sauer » Wed Jul 03, 2019 1:23 am
Had a look at some of my pictures and my center ones are Bobbons as you?ve noted but the outer most upper ones on my dash as well are cut away and I?ve seen this on other dashes as well and I don?t know what the reason would be but I didn?t try to rebuild those. Gordon Sauer
12b2ac37-4838-4c72-b54b-dcf443c47f3a.jpeg and
Gordon Sauer
PostPost by: 1969Plus2 » Wed Jul 03, 2019 1:29 am
Interesting. I can?t possibly imagine why you?d cut them away. Maybe they were frail and broke on disassembly?
1969Plus2
First Gear
First Gear
PostPost by: sveris » Wed Jul 03, 2019 7:32 pm
Frail and broken off - probably. Same flimsy tabs found on Europas, too.
Steve in Ohio
sveris
PostPost by: Bigbaldybloke » Sun Jul 07, 2019 12:18 am
Just visible is the broken top right tab for the dashboard bolt. The centre ones have threaded bobbins bonded in on mine 1967 car but the outer ones just had a nut and washer on the back, as can be seen part of the tab has broken off and needs remaking in fibre glass, one more job on the to do list!
649101be-baa6-46d6-852a-6f5b205ca9c4.jpeg and
Users browsing this forum: No registered users and 43 guests
