Motor mount failure; New Pirelli cn36
Almost a failure that is. The left side Spyder engine mount was about 1/4" away from separating. The break started at the bottom so it wasn't visible from above. I'm feeling very fortunate to have noticed it as it feels like it was about one mash of the gas from failing. Attached is a picture.
BTW, if you haven't seen them yet, check out Pirellis new cinturato cn36 tires.
- webbslinger
Another reason to stick with a folded chassis... not a fan of spyder chassis since owning one...
- grassyknoll
No idea what caused the crack other than I drive it a lot and have hit a few whopper bumps. I'm a fan of the Spyder frame, but the mounts looked pretty thin. As lucky as I was to catch it before it failed, there was a bit of rust so it had been there awhile and I should have noticed it sooner. I put it up in hopes that everyone will look at theirs.
I had it welded this morning and it's all back together now.
- webbslinger
Where did you see new CN36's ? I had them on my 73 VW Sports Bug and again on my 74 Europa Special. Hands down, they were the best tires I ever had in my life. I'd buy more today id I knew where. The Bug won the National SCCA Solo II Title and the Europa came in second at the Nationals also.
Frank
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
The cn36 tire is available in the US from Lucas Classic Tires in Long Beach, CA. They are also available in the UK.
- webbslinger
Users browsing this forum: lotusfan and 21 guests
