S3 3 point seat belts
I'm looking for some advice. My car has made in England Irving parachute company seat belts that were installed very early on by the original owner.
I'm thinking about buying some new belts that look period correct. I have read some of the older posts but wanted to get some newer feedback.
Rick
These are not the type that were made in the USA, therefore getting them restored is going to be a project. I'm not sure what happened to the originals, or if the car even had any belts. Belt mounting points are the two low points for the lap belts and one up high and outboard for the solder belt. The car was purchased new in Canada. I'm thinking about buying some new belts that look period correct. I have read some of the older posts but wanted to get some newer feedback.
Rick
- rcombs
I have the same exact set in my late S3. I am also interested where I could find a set or get them re-webbed.
The label also references a "British Parachute Specification"!
Thanks.
Dan
Thanks.
Dan
Hi Rick,
I had the same situation. I sketched what was needed from a friends S4
I watched on ebay for Kangol magnetic seat belts and kept buying them ,or parts of, until I had all the fittings.
They can be cheap if the seller does not know they were fitted in Lotus and Jaguar cars.
It took a while.
From the breakers yard I took unused webbing out of the rear seats of a Ford Mondeo.
The local cobbler stitched them up for me copying the original stitch pattern and refitting the labels.
They look close to original.
They sometimes turn up in new condition and some one on ebay advertises restoration to original condition.
Best of luck,
Eric in Burnley
1967 S3SE
It took a while.
Best of luck,
Eric in Burnley
1967 S3SE
- ericbushby
Rick
You may like to look at this company in UK, they can probably refurbish your belts. They seem to be well respected.
https://www.quickfitsbs.com/index.php
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
I had my original Kangol seat belts from my S4 SE DHC refurbished by Sue Miller. New webbing, new Lotus stickers, and using proper Kangol sewn-on labels. Sent my belts from California to UK and back.
Don't know if Susan has replacement belts.
Here are the belts prior to refurbishment. Shows the various parts involved. If you can collect the parts, undoubtedly Susan can put an original set together for you.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
The Irvin belts came in various lengths and fitting types, they were fitted to Mk 1 Lotus Cortinas, Elites, type 26's and very probably to early S3's.
NOS belts sometimes come up on eBay and they change hands for upwards of ?600.
Original webbing is no longer available, but I'm sure you could find something close.
Mazzini - Coveted Fifth Gear
Hey everyone, Thanks for the info.
Dan, nice to know you have these belts; mine car is a late S3 also. I double checked the owners records and they don't show that he replaced the belts; so these may be originals as well. I don't know why I thought they were replaced.
I may check with Sue Miller and and some British outfits and see if the Irvings can be restored. Dan, if I find out they can be restored I will let you know.
I knew that most Elans came with Kangol belts. I have been watching ebay, but I will check with Sue about those as well.
Has anyone bought any of the new retro style belts? I may fit those until I arrive at a final solution.
Rick
Rick
- rcombs
S3 S/E's came with Teleflex reel belts, I have a set, I wouldn't use them as I don't think that they're safe. It wouldn't surprise me if your car originally came with them, but they failed early on and the Lotus agent supplied the Irvin belts to replace them.
I'm sure somebody on either side of the Pond will be able to restore them.
Mazzini,
I have always read that the S/Es came with reel should belts, but I don't know how they would have mounted them. My frame has the brackets added to the top of the rear turrets. The shoulder belt anchored through the outboard corner using a single mounting stud. I would be interested to know how yours were mounted.
Rick
Rick
- rcombs
rcombs wrote:Mazzini,
Rick
The Teleflex belts had a large off white metal and plastic reel mechanism fitted by a single bolt to the top rear chassis mounting bolt, the bottom of the belt was connected to the mount in the side metal lattice work. The receiver was in the usual place, but it was was made almost entirely out of plastic... which seemed to break early on.
tvr78 wrote:Drive without belts,it? better to fly out than to wait for someone to crash into you.try to avoid an accident .it?s not a very safe car especially with all the idiots nowadays in their suv?s that are 4times as heavy as an elan.
I do hope that no-one gives any credence whatsoever to this idiotic post (apart from being illegal it?s just plain wrong).
elanfan1 - Coveted Fifth Gear
Hi Rick,
I had my grotty Kangol belts from my Europa refurbished by FDTS Ltd in the UK. They were very good to deal with and provided a full breakdown of costs and optional extras. http://www.fdts-seatbelts.co.uk/ .
I?ve no personal connection to them, just a satisfied customer.
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
Here is the US, try SnakeOyl
https://www.ssnake-oyl.com/
They did my LoCort belts many years ago. Not cheap, but done perfectly.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
