Boot hinge???
Good morning Kurt,
Like this?
https://paulmattysportscars.co.uk/produ ... nge-s1-s2/
https://kelvedonlotus.co.uk/product/boot-hinges-pair/
Like this?
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
Thanks much.....but the Kelvedon ones say they can be polished or plated. Sounds like they may be aluminum. P Matty shows nice plated ones so I guess contacting them will be the proof. Only ali ones were available at one time I believe.
Kurt
Kurt
- nomad
Despite what some authorities have stated (not here) both the Type 26 boot hinges and door handles were Lotus special parts only. Anyone know why? There were plenty standard designs around at the time, though usually Mazak and not brass.
Meg
Isn't the front end of the hinge angled the way it is to retain the rear edge of the hardtop. You'd think someone else might have done the same, but perhaps making a new, unique hinge / bracket to do two functions may have outweighed using an existing part. Those hinges continued to be used in the early pre-airflow Coupes and I think, maybe into very first S3 DHC production. I am restoring a pre-airflow FHC w/ those hinges.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Can you not just have them re-plated? On my S1, I just removed the pivot pin, drilled it out a bit to fit a standard size roll pin, then had them re-plated.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
bitsobrits wrote:Can you not just have them re-plated? On my S1, I just removed the pivot pin, drilled it out a bit to fit a standard size roll pin, then had them re-plated.
Yes, I did that without realising the pins were a push fit. Fortunately I knew someone who added brass and I redrilled the lot for a solid SS pin.
I think the hinge probably was designed to solve the hardtop mounting problem. S3 cars used them though I think the change to the new hinge came before the S4.
Meg
That was my plan, Steve, but some how I have misplaced the good hinge....looked high and low. The other had a stud broken off in it and the PO didn't do it any good trying to extract the broken bits. If I can get it out I will have to drill and tap for a larger stud. Soooo, I'm looking at alternatives!
Kurt.
26/3754
- nomad
Users browsing this forum: mfast and 16 guests
