s3 door markings
So, I've pulled the door card off and the attached covering to the door and saw this
number written on the door. I'm fairly certain the door is original to the car, only because
the car is originally BRG and so is the door, in areas where a re-painter wouldn't go.
The car's VIN is 5727
The door also has the window switch hole but my window switches on in the dash.
Does anyone know the significance of this number?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
If the door is original to the body, the same number should be on the firewall near the starter solenoid. It will look like an embossed label.
Dan Wise
Dan Wise
And check the inside of the other door too. The body number in the firewall area is what we used to call a Dyno labeler.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
