S3 coupe parcel shelf mounting
I removed my parcel shelf to access the top of the rear struts but the mounting of the shelf doesn't seem
correct. I had to pull back glued in carpeting to access several mounting points, as seen in the pictures.
Is this the correct way to mount this shelf? It seems to me that it would make more sense to have the
shelf sit on a bracket, of sorts, rather than mounting it straight onto the back bulkhead.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
gjz30075 wrote:Aha! Mine were screwed into the masonite bulkhead, which required pulling the carpet back to get to the
screws. Maybe they shouldn't have been?
well now that you're saying this I'm not 100% sure... must be getting old, it's been a few years since I last tinkered with it, and now the car is stored away so I can't look if there are screws or screw holes (in case I did not screw it back). Other issue is that I had a "pro" upholstery shop do the carpet, they may have messed the original installation...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Yes back of the shelf sits on clips mounted around the rear glass mounting fibre glass flange. The front of the shelf sits on the vertical board and is secured with the clips you show under the carpet.
Long ago I drilled a couple of holes in the parcel shelf and inserted rubber plugs as fitted in the DHC to give access to the top of the struts without removing the "parcel shelf". Who ever puts a parcel on it ?????
Thanks guys. I recently found a private website (can't find it now) about a FHC restoration and it showed
several 90 degree brackets mounted on the bulkhead and the parcel shelf sitting on those. I'm thinking
velcro here.
velcro here.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
rgh0 wrote:Long ago I drilled a couple of holes in the parcel shelf and inserted rubber plugs as fitted in the DHC to give access to the top of the struts without removing the "parcel shelf". Who ever puts a parcel on it ?????
Now theres a good idea. Having to take the parcel shelf out to get to the rear shock adjusters means they're only adjusted whenever I strip the suspension down.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Greg:
I noticed your 2018 post about considering velcro to hold the front of the rear parcel shelf in place instead of the hard to remove brackets. Did you do this, and how did it turn out?
Any increase in squeaks or rattles caused by the velcro vs the brackets?
I am about to remove mine to cut 5" holes to install a pair of 6.5" speakers, and thought the velcro idea would be great as far as future removal and access.
Bill Moore
67 Elan FHC
Bill Moore
67 Elan FHC
1967 Lotus Elan FHC Spyder Chassis
1972 MGB (since 1975)
- billmoore42
Bill, no, I haven't done this job yet. It'll be done when I redo the carpet, however, I was recently looking
at the shelf, thinking of this job because I may relocate the front tabs but I don't see any reason why it can't work.
The shelf is just sitting on the front and rear tabs and really doesn't 'rattle' or move around when driving.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
