Which sills?
I think shipping will be around 150.00, my usual guess(:
Good luck
Good luck
Nick Baxter
1970 Plus 2S (Federal)
1969 Plus 2 (UK) - sold
- nwbaxter66
Check out the link you posted for me. Shipping is estimated in the details at $46.20 to the US. If that's correct, it's a no brainer. (I was quoted twice that from another British supplier fora set of wiper arms and blades)
Someone also posted in a previous but related topic a list of additional parts, seat belt mounts etc. to order at the same time as the sills. Any thoughts? I'll post the link if I can find it.
Tom
Tom
- TomMull
While you are under the car check the top seat belt mounting point reinforcing plates in the wheel arch, mine looked fine till I tapped them with a hammer and they just crumbled. See picture of original and new plate.
- Bigbaldybloke
I have a question about the body jacking point holes in the sill.
Should there be a rubber grommet/blank or something that fits in the fibreglass on the sill to cover both the metal jacking point and the fibreglass surrounding hole?
Mine has nothing and I just wondered how to stop rainwater/muck going in?
'71 +2 S130/ 5speed Type9.
- alanr
I'm not aware there was ever a seal/grommet to seal the jacking points. I would recommend a good dose of waxoyl or similar before the wheel arch closing plates are attached. When fitting my spyder sills I was pretty generous with silicone sealant on any fittings .. hoping to avoid that damp musty smell
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
When I had the body resprayed the jack holes were filled in. I have the dimensions as to where the holes should be so they could be opened up if necessary but I have no intention of ever using them to jack from. My sill members are stainless steel and I have new alloy closing plates sealed in place.
- Bigbaldybloke
Bigbaldybloke wrote:When I had the body resprayed the jack holes were filled in. I have the dimensions as to where the holes should be so they could be opened up if necessary but I have no intention of ever using them to jack from. My sill members are stainless steel and I have new alloy closing plates sealed in place.
Interesting...
So when you are at the side of the road with a flat tyre what do you do?
- alanr
Call the AA/RAC/Greenflag, saves me getting my dainty hands dirty
- Bigbaldybloke
I wouldn't cover those holes. There's really no other good way for that area to drain condensation or any water ingress. That area seems to attract dust and moisture no mater how well you try to seal the blanking plates.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
