Headlamp unit removal!!
As a follow up to my last post I removed the headlamp units from the pods. A fairly straight forward job if you realise that the release tang for the chrome trim can be accessed through the drain hole at the base of the pod, I suspect most of you know this already.
One of my pods looks as though it may be a replacement as it is lighter than the other which also carries a tag B2.6 which I assume is an id number,,,see what you think.
https://youtu.be/Mk6k9uPx3GA
- djb222
May I point out that there should be no need to access the spring catch through the drain hole. I made the tool for releasing the rim, which is shown in the workshop manual. Section M page 89.
It is just a sheet metal hook which fits behind the rim to pull it off.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
