Were Elans made LHD ready??
In my engine bay at the end of the passenger footwell there is a 'pop riveted' thin fibre board cover. It seemed an odd and out of place item, so before removing I thought I'd have a look inside and found that it covered cut outs for brake and clutch cylinders. The car was registered in the UK and to my knowledge has ever left or been converted to LHD.
So is this something that Lotus did as a matter of course??
- djb222
I would not be surprised. I know my dad purchased his S2 as LHD right from the factory in England, but I don't know much about it beyond that.
1965 S2 26/4623
- benymazz
My very original early S3 (LHD) had the riveted fiberboard over the holes for RHD controls. I once had another RHD S3 that had the same setup, but on the LHD side. I would have to believe this was from the factory.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Certainly they were LHD ready from the start. Chapman was smarter than to think he could ever turn a profit selling only in the UK. MG and Triumph had already proven that the U.S. market was where the easy money was. And the Continent is not RHD either.
- denicholls2
I must say that was my initial thought, however unlike other manufacturers, who had to have tooling to produce the panels to accommodate right and left, with lotus it was just a few holes, presumably after moulding. Also, it looks like they forgot the hole for the Steering column (in my car)........unless I've missed it.
Has this always been the case with the +2, Europa etc........and what about the more modern Lotus?
- djb222
Interesting....... Having worked on a number of rhd Elans now i don't remember seeing a second set of LHD holes? i suspect all the Elans (pre-federal) started off life with a set of RHD holes and the LHD set were added later in production to meet orders, so maybe you just ended up with a Body that was originally destined for sunnier climates and for what ever reason stayed in the Uk.
Grizzly - Coveted Fifth Gear
My rhd S2 has the holes with a type of fibre board over them and my old S3 (sold) also had the holes covered with the board.
Have not checked my Sprint as its in storage at the moment.
I have a 1965 S2, a 1967 S3 and a Sprint (all UK RHD) and in the past I have had S1's, 3's and 4's (also UK RHD) and they've all had the holes cut out for LHD and covered over with board of some type (same stuff used to cover over the fuel tank hose to main pipe I think).
Mazzini - Coveted Fifth Gear
My federal Plus 2 has no RHD holes. That said, it looks like the holes could be cut on either side.
And since more modern Lotus came up, my former '86 Esprit, if I recall, had a body made for one side and not the other; however, the dashboard's exteriour trim appear appeared to be designed to be used on either type- there was a big rectangular hole on each side, which on one side accommodated the instrument binnacle and on the other side accommodated the glovebox-lid.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
My 1972 130S had a fiber board cover over some holes on the top of the right side footwell. The holes were not large enough to accommodate the pedal assembly, and I couldn't quite figure out why the holes were there. Repaired when I did the engine conversion.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
The Veg wrote:My federal Plus 2 has no RHD holes. That said, it looks like the holes could be cut on either side.
My Elise had a hole for a LHD pedal box with a plate (badly) riveted over it.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
