What is this missing piece of interior trim next to dash?
• Page 1 of 3 • 1, 2, 3
I'm looking for the piece at both ends of the dash. It looks like when it was previously restored, this piece was not sourced nor replaced.
Thanks!
1967 Lotus Elan Coupe - Super Safety
2019 Tesla Model 3 Performance
1973 Ford F100 4x4
1973 Ford F100 4x4
MrBonus - Second Gear
For me nothing is missing but the Trim along the top of the Dash has dropped down. Maybe you can warm it up gently with a Hot Air Gun and slowly push back to the original shape.
- alan.barker
alan.barker wrote:For me nothing is missing but the Trim along the top of the Dash has dropped down. Maybe you can warm it up gently with a Hot Air Gun and slowly push back to the original shape.
Ah, then I'll just leave it be. Thanks!
1973 Ford F100 4x4
1973 Ford F100 4x4
There should be a filler piece attached to the A pillar trims:
Available from Paul Matty - https://paulmattysportscars.co.uk/product/elan-screen-pillar-trim-set/
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
pharriso wrote:There should be a filler piece attached to the A pillar trims:
Fantastic, thank you!
Google had failed me on this piece and was starting to wonder if my dash had been custom modified or something.
1973 Ford F100 4x4
1973 Ford F100 4x4
And if it is a late S3 (mine was a S3SS) it will have an air vent in it.
types26/36 wrote:And if it is a late S3 (mine was a S3SS) it will have an air vent in it.
Maybe I'll just put a glass eye in there.
1973 Ford F100 4x4
1973 Ford F100 4x4
Yes its better to keep an eye on it ..........
But seriously your heater may have the outlets for the vents and if so you will have a draft blowing in all the time as it is closed off by the vent.
I thought all Coupes have vents there ... your car is DHC or FHC ?
1964 S1 (engine ready, awainting body paint)
1967 S3 DHC (left window stuck)
1969 S4 FHC (waiting for return pickup)
Brian Bucklands 2nd edition available ! Look here: https://theelanman.com
- gherlt
I thought the pre-air flow Coupe's did not have the vents.........could be wrong though.
Just checked my books and the S3 Coupe's started at 36/4510 Sept 65.
The air vent fitted from #6600.
I made a mistake there should be the moulded part with the little vent. The vent is a bit of a gadjet that moves about between open and closed
- alan.barker
gherlt wrote:I thought all Coupes have vents there ... your car is DHC or FHC ?
FHC.
1973 Ford F100 4x4
1973 Ford F100 4x4
types26/36 wrote:Just checked my books and the S3 Coupe's started at 36/4510 Sept 65.
As with most things Lotus......
- elancoupe
My 67 S3 coupe originally had those air vents, but the first renovators in 1982 did not replace them after the re-covering of the soft bits.
