Tonneau install
I?ve decided to install the tonneau on my Elan S3 myself. Can someone recommend a source for the leather punch needed to do this?
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
This is probably what you need
https://www.woolies-trim.co.uk/product/ ... ting-punch
but I'm sure http://rdent.com/ will stock what you need and the postage will be less!!
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
I used one of these in a screwdriver holder
https://www.amazon.com/4-Piece-Plug-Cut ... B00BFY3DQ8
Using it a bit like a bradawl. I am sure there is a proper tool out there but it did work really really well.
Good luck
Terry
Good luck
Terry
- terryp
Thanks all!
I ordered this from Amazon
https://www.amazon.com/gp/product/B000K ... UTF8&psc=1
Looks like it can also be used to cut holes in gaskets.
67 Elan +2
67 Elan +2
- seniorchristo
I don't know if you have ever done this. There are some tricks. I have done lots.
You start at the middle, working your way towards the outside. Doing one then the other closest to the middle switching back and forth from one side to the other.
You use masking tape on the underside of the tonneau. Pressing down on the tonneau where the masking tape is on the underside of the tonneau. Pulling it tight as you do one then the next. The masking tape will indent so you know exactly where to put the fastener.
That is about all. Very simple if you take your time.
Tony V
Tony V
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
Thanks for the tips Tony! It's my first attempt but I'm pretty sure I'll be more finicky than the shop I talked with. I'm also going to wait for a hot sunny day. It looks like it needs to stretch a few inches to fit properly.
67 Elan +2
67 Elan +2
- seniorchristo
seniorchristo wrote:Thanks all!
To cut screw/bolt holes in a Gasket, place the Gasket on the part it is to fit and place a Ball Bearing over the hole.
Tap the Ball Bearing with small Hammer and the hole is cut
- alan.barker
Well I completed the install. Yesterday was perfect in PA, sunny and 95 degrees F. Thanks for all suggestions to assist. I'm quite happy with the results and I highly recommend the everflex tonneau supplied by Paul Matty. Just be sure to order the extra zippers. Also be specific about your seat type. I ordered mine for a US LHD S3 but they were going to send me one for an S4 (high back seats).
67 Elan +2
67 Elan +2
- seniorchristo
Looks great Chris! Congratulations !
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
yes, looks fantastic. I learned the hard way to start from the middle. On my Sprint (now in the hands of Tom S down in Houston) I started from the side and when I got to the other side I was way off.
Looks like a great job. Glad I could pass along some tips to you.
Tony Vaccaro
Well done that man, that's what the forum is all about sharing and giving tips
- alan.barker
Thank you kind sirs! Now I can attend LOG 38 and not worry about a few raindrops.
67 Elan +2
67 Elan +2
- seniorchristo
I have just ordered one of these, can you explain the issue of the zippers.
Also do you have a photo from the side of the car with the cover in place?
- Terry Posma
