Interior cardboard replacement.
I think that Sue?s part is pickup only, due to the size.
I could make them out of grp, but cutting them out of a sheet of something would be a lot easier.
I read something on here about using a type of thin plastic, haven?t been able to find it. #whatashock
- elancoupe
I used 3mm foamed PVC sheet for the cockpit back panel and the rocker panels. It's lightweight, rot proof, cuts and bends easily and can be formed with a little heat from a hot air gun or hair drier.
S4 DHC
S4 DHC
- oldelanman
I used the old panels as templates (had to tape the bits together ) and then cut new ones out of 3mm hardboard.
A bit stiffer than I would have liked, but worked never the less.
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
- pcarew
On the recommendation of a local upholstery shop I used automotive panel board. It worked great and it is supposed to be water proof and it is made specifically for auto restorations. The original pieces were fine but I didn't want to cut them to fit around the roll bar I added.
- webbslinger
Hi !
I make sheeter for plastic and I got an order for inline sheeter of Bubbleguard that it?s like the polyethylene bubble pack but rigid because made of polypropylene and already laminated with a layer of non-woven that make easy and stronger the glueing of the carpet
I started with the inner sill then the job was so exciting that I cannot stop so I made back board, sills under dashboard panels trunk etc etc
Have a look of the pics
Ciao da bella Italia
Paolo
Paolo
- lotusbzz
