Castor angle
Just now I'm setting up my recently fitted Spyder adjustable front upper wishbones. My castor with equal settings was way off, -0.28' lhs, + 0.04' rhs, i.e. one side negative, and the other about zero
My Autobooks Lotus Elan/Lotus Elan +2 manual Tech Data quotes the castor as "Early, 7 degs ; later 3 degs + 5 degs" (I think this typo should read 0.5 degs)
My original Lotus manual for the Plus 2, Section C, Front Suspension, P6, shows 3 degs + 30'
I'm shooting for 3 degs and I'm looking forward to see how it works out.
Has anyone any knowlege on why the change was made from from 7 to 3 degs ?
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
The more caster, the harder it is to turn the steering wheel when stopped or a very low speeds, like parking. Perhaps there were complaints?
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
There is also the saying, " Caster is faster". You can run less negative camber for increased speeds on the straights, and when turning into a corner, the caster will increase the negative camber.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
prezoom wrote:There is also the saying, " Caster is faster". You can run less negative camber for increased speeds on the straights, and when turning into a corner, the caster will increase the negative camber.
That never occurred to me but makes sense!
Kurt
- nomad
