Roof gutters
KevJ+2 wrote:Weren't the earlier ones chromed brass and later ones ally?
Yes that is correct, but the early ones could be fitted to a later car.
There are two types shown in the parts list with a change date of Feb 1970
- elanman999
Ah . . . silence for that last question. Inquiring Plus 2 owners would like to know.
I will hazard a guess: no one is making them currently, so anything you find will be NOS or used. My go-to UK supplier of Lotus parts, SJ Sportscars, does not list this part.
Interesting that another "rare-as-hen's-teeth" part, the so-called moustache trim around the nose air intake, has been re-made, I believe. Perhaps it's not too much of a stretch to see the rain gutter trim being remade at some point. On the other hand, the early Plus 2 interior console has been MIA for decades.
You might consider filling the mounting holes, if you're doing bodywork/paint, so that you can run the car without, until such time as you find a set.
Randy
Randy
So I wonder if these came from another vehicle or were bespoke. Much of the bright-work was from other vehicles but maybe the door tops and gutters had to be purpose made?
Don't mention that you're prepared to pay a fortune for your roof gutters as you'll have lots of dodgy caravan dwellers offering to do the work for you before driving you to your nearest ATM for payment
- KevJ+2
NYK
I have a 72 s130, it had the alloy type fitted when I bought it but one was damaged,I managed to get a pair of brass ones, however they were shorter, if you aligned them so they fitted flush with the rear of the roof, the curve at the front windscreen was shorter and exposed a securing hole where the original one was fitted,probably won't matter if you don't have any holes in the A post but mine has and is still exposed .
Regards phil
Regards phil
- p.faurie
Thanks Phil, I see you are in Kent, do you mind me asking where about. You have the same year/variant as mine and it might be useful to see what various bits look like. I bought mine part restored so there are some details that I?m not familiar with.
Nic
Nic
- NYK
Users browsing this forum: StressCraxx and 22 guests
