Where does the main earthing cable run after leaving battery
Here's another guys,holes sorted thank you.
Where does the main earth cable run after leaving battery negative earth, it must go to the chassis, but how and where?
Bob
Bob
bloodknock - Fourth Gear
Tight to the fibreglass behind the carpeting down to the boot floor and fixed via bolt through the holes to the chassis. It's always a source of problems so you might want to consider relocating to a drier and more accessible place like one of the rear uprights.
elanfan1 - Coveted Fifth Gear
OK hear what you say - any pictures?
On my Plus2, grounded to the rear most chassis mounting bolts. Originally mine went to the bolt closest to the battery. To double my chances, I bridged the cable to both bolts. That and a new number one red battery cable to the solenoid. Lots more strands and a lot more flexible.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
S2, or S4? Elan or Elan Plus 2
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
hi
its a sprint....when in one piece!
bob
bob
It runs toward the front of the car about 10 inches then down to the floor along the corner of the boot, then towards the center of the car and attaches to one of the bolts that are at the front of the boot, center of car that go through the chassis.
Whole length of cable cant be more than 3 or 4 feet.
Tony V
Tony V
Tony Vaccaro
Here's a photo taken for other purposes but it shows the earth cable and attachment point.
'67 S3 SE FHC
'67 S3 SE FHC
It, as has been stated, bolts to the remaining threads of a bolt that comes up through the chassis and through a threaded bobbin in the body.
Therein lies the main problem with it.
If that bolt is not done up tight the head of the bolt can be slightly clear of the chassis, and making very poor contact, but you'll be unaware of that.
Because you can't see it...
The answer is to run a drill through the bobbin and remove the threads.
Then it does do up tightly, and you'll have no more problems.
Found this out 40 years ago and welded the bolt head to the chassis as a quick, ( and dirty..), repair.
Real bugger when I came to change the chassis !
Ralph.
Ralph.
- reb53
