Door seals
I believe they are original as they are on DHCs as well. Can't comment on material or size I'm afraid
'72 Sprint
'72 Sprint
- richardcox_lotus
I use a standard L section here from Baines. You can buy metres of the stuff for what you'd pay for two ready cut pieces!!! Take care removing the aluminium strip that holds it on though. I think its purpose is to route drips away from the interior of the car rather than to seal, but I might be wrong. I'm sure others on here know the true purpose.
NRBF
NRBF
- nigelrbfurness
pharriso wrote:They are called Secondary door seals; Ms. Miller has them in stock.
So glad you called her 'Ms' and not Mrs... A lot of people have been trying to forget Mrs Miller
https://www.youtube.com/watch?v=fw07CDid0JM
She performed for troops in Vietnam, which was just cruel, how bad could your life get?
Listen at your own peril.
Mazzini - Coveted Fifth Gear
nigelrbfurness wrote:I use a standard L section here from Baines. You can buy metres of the stuff for what you'd pay for two ready cut pieces!!! Take care removing the aluminium strip that holds it on though. I think its purpose is to route drips away from the interior of the car rather than to seal, but I might be wrong. I'm sure others on here know the true purpose.
NRBF
Thats my solution:
I never had water in the car at this area.
ElanDNA - Second Gear
