S4 DHC - Inertia Reel Seat Belts?
I want to fit a new set of set belts to my S4 (1970 dhc) and I'd prefer inertia reel belts if possible.
I haven't found anything locally so far (Sydney, Aust.) but find plenty of ads on the internet/ebay in the UK - e.g. Securon.
Would be interested to hear from someone who as actually done this recently - prerequisites, traps, etc. - and exactly what belts they fitted, from which supplier. It's a long/expensive process to return them if I get them shipped out and they aren't right.
Appreciate any feedback.
Elliott - 70 S4 dhc
ElliottN - Second Gear
I fitted some to my coupe. Check my resto blog on here to see the details. I made the brackets myself and bought the belts from Burson or Repco. On the buckle you need to loop the belt back through the other way so that the bolted connection and the bucke all sit in the correct orientation - ie no twist in the belt. It's simple. Just unpick the belt, reloop and restitch. If you need any more detail let me know.
europatek - Second Gear
I was toying with the idea of fitting a Spyder cars conversion http://www.spydercars.co.uk/lotus-elan- ... rsion-kit/ i like the way the bracket mounts to the car. Only problem is Spyder cars are on the wrong side of the world for you, but hey the UK exchange rate is low at the moment........
Grizzly - Coveted Fifth Gear
Elliott
There has been some previous discussions on this and FWIW I fitted the Spyder set which I found easy to install and works well. I have posted some photos in the past.
lotus-chassis-f36/backboard-and-inertia-reel-seat-belts-t34282.html.
If this does not work I can repost or PM them to you.
My installation was in a 69 S4SE and should work for yours and it certainly did not involve any cutting / restitching.
1969 Elan S4 SE
1969 Elan S4 SE
- HampshireMush
Late Federal Elans came from the factory with Kangol Reflex Inertia Belts.
I have restored my car to have Kangol 2nd generation Inertia Belts:
The belts were used on TR6s, I restored the reel mechanisms & used new webbing.
As detailed in the Buckland book there is a reinforcement plate to mount the reel & a rod between the reel & the upper mounting.
Before I decided to go back to original belts I researched what was available new & concluded the Spyder kit was very good, as is the Securon 514/30 kit.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Thanks for posting this info guys. I am trying to figure out what to do with my car. It's a '67 SE, but the originals were replaced the the late '60s with Irvin paracute safety belts. I'm trying to decide do I redo the Irvins, try to find some impossible to find originals, or go with new belts.
I am going to to look up some suggestions listed here.
Rick
Rick
- rcombs
rcombs wrote:Thanks for posting this info guys. I am trying to figure out what to do with my car. It's a '67 SE, but the originals were replaced the the late '60s with Irvin paracute safety belts. I'm trying to decide do I redo the Irvins, try to find some impossible to find originals, or go with new belts.
Rick
I have the Irvin's in my Elan. They are simple and work well.
Dan
I have fitted Spyder inertia reel belt to my 1970 S4 DHC.
After a bit of trouble moving the slots on the back board and re carpeting the reels work well.
However I have a problem with the short receiver belts that bolt to the transmission tunnel.
They are too short and if you fit the extension brackets supplied you have another problem.
The seat belt bolt heads hit the seats. There is no room even after removing the sound proofing.
It is not possible to tilt the seats and the bolt heads will cut the upholstery if left like this.
Any ideas please?
Rob
Any ideas please?
Rob
- roebuck
Hi Rob
I have fitted the Spyder kit (see previous post by me) and whilst I bought the extensions as well thinking they would be needed found that they fouled the seat and where also way to far forward when fitted.
I am about the same height as you - probably shorter as I have shrunk a bit with age! - and find that just using the basic stalk is fine. I do tend to drive with the seat back in any car but not excessively so. The seat buckle is tight between the seat and the tunnel but works well for me and needs a little extra effort fitting and releasing but better than the alternative.
1969 Elan S4 SE
1969 Elan S4 SE
- HampshireMush
