Hood Hinge Skid plates
I struggled with this over an extended period so I am posting information here in the hope that it will help others.
I found no information in the forum on how the Hinge skid plates should be mounted on the hood (bonnet). My car was missing the skid plates & the end area of where the skid plates attach to the hood by rivets was damaged.
The skid plates mount on the underside of the bonnet & slide on Nylon bolts/nuts assembled on the body. The plates & bolts/nuts are readily available from suppliers such as Matty & Sue Miller.
When I bought skid plates from Matty I did not know how they were attached to the hood. Laying the parts on the hood they appeared to be too long, so I duly shortened them & re drilled the rivet holes.
I recently acquired a 2nd hood that came with skid plates already attached & I could see that I had attached the plates incorrectly:
So I have subsequently repaired the GRP on the end area of the plate, taken the opportunity to widen the area & attached new skid plates:
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Phil,
Thanks for the guidance.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Thanks for providing this info about the skid plates. My car doesn't have them and I didn't even realize there was something missing. I'll add this to my winter project list.
Rich
Rich
"What kind of a man are you? Don't you even like dolphins!?" - Zorba the Greek
69 Elan S4/SE DHC
66 Ford Mustang Conv. (289ci)
71 Cadillac Eldorado Conv. (8.2L)
65 Buick Wildcat Conv. (425ci)
And a pickup truck full of Miatas....
69 Elan S4/SE DHC
- SF69Elan
Wait... I JUST acquired S4 9292 (last week) and was a bit miffed that someone had removed the front hinges from the hood.
You mean there aren't supposed to be any?
Is there a procedure for removing the bonnet alone without possibly chipping paint?
Chris in Gettysburg
Chris in Gettysburg
- Gettyselan
I have no spring on mine, because I have a lock at the windscreen end of the bonnet, so I can use the key to lift it enough to get hold of the bonnet top.
Then I simply lift it (rotating on its skids) until it is near vertical then lift it off. No paint chipping at all.
Billwill
Is that lock easily obtainable please?
Kind Regards
Kind Regards
Love your Mother
Earth
Love your Mother
Earth
Users browsing this forum: wolfchen and 27 guests
