S4 Bonnet Spring
I was watching a Elan Sprint video that Harry Metcalfe (EVO magazine) made and noticed how easily he removed the bonnet spring from the hook on the front of the bonnet. Mine is under a lot of tension and I'm thinking have I installed incorrectly? Does it wrap around the steering rack?
Mine is extremely hard to put on the bonnet hook. By the way, same with my S1 dual springs, very very tight.
Any insights here?
Any insights here?
Last edited by Certified Lotus on Tue May 17, 2016 9:34 pm, edited 1 time in total.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
On my Sprint it is easy to remove the spring from the bonnet once the bonnet is held upright. I can do it one-handed while the other hand supports the bonnet. It is one of the really sensible features on the 2-seater Elan.
Not sure what you mean. The loop on the lower end of the spring goes right round the rack. In fact I don't think it can be removed without taking the rack out. You can see it clearly in this picture of my chassis.
TroonSprint - Fourth Gear
Like Mike's, mine is easy to fit & remove when the bonnet is raised. It seems sensibly tight. When releasing the closed bonnet with the dashboard handle the spring is strong enough to raise it about 6-8 inches.
I always leave the bonnet open when the car is parked in the garage on the assumption that it will reduce the chance of fibreglass stress fractures on the front edge. And it helps cool the engine.
Nick
Nick
elanner - Fourth Gear
I put a keyring, about 1 inch in diameter onto the bonnet bracket, so when the spring is hooked up, it will relieve some of the spring tension. I remember seeing a S4 once that sat outdoors for years and the bonnet was severely distorted in that area. So, I wanted to lower the spring tension and hope it wont happen to mine.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Thanks for everyone's responses. The key ring concept is a good one. Does anyone have a measurement of the spring uncompressed? I wonder if mine is too short?
Glen
Glen,
Measured my spring for you yesterday. I have a radiator blanking panel that covers the rack with a hole for the spring to fit through, so it's a bit awkward to measure accurately. Plenty of room for parallax error. However, as best as I can gauge:
- Length of spring coils, at rest: 5 1/2"
- Top coil to hook: 1"
- Top of rack to bottom coil: 1 1/2"
Nick
Nick
Nick , thanks for the measurements! It's interesting that your spring compressed is 5 inches as mine is 7 inches. Phil, the one you just bought is in between Nicks and mine. So I guess the tension on mine is correct.
Never the less, I did "lengthen" it by adding a stainless steel fitting from a boat. Working great and now does not add more stress to the front hook on the bonnet. Plus now I can just reach in to lift the spring off easy to remove the bonnet.
Glen
My spring is really easy to remove, but it seems almost too weak as it barely lifts the bonnet at all when I release it. It used to be really tough, but since Option 1 repaired the bonnet and fitted a proper hook it seems that I need to get a slightly shorter spring.
1967 Elan S3 S/E FHC
adigra - Fourth Gear
my s4 spring is a bit of a bind to get off and on.......which thankfully is not very often......
what I did was to buy a bunch of cable ties for a pound or so, round the spring an bonnet hook.......infinitely adjustable and disposable ......just snip off! [apologies to environmentalists... ]
fred
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
