Series 1.5 and Series 2 inner door lock "knob"
Hi, does any one have pictures of the correct finishing knob for the inner lock for the above cars please. It seems to screw onto the rod that comes off the lock assembly.
I'm keen to se if i can get a set scanned into 3D file to have a test set 3D printed
V
V
- vstibbard
I'm missing both too. If you succeed, let me know and I would like to buy a pair from you.
same deal with the eyebolts that hold the front of the cantrails to the windshield. apparently their are unobtainable.
Carlos Guerra
Carlos Guerra
- cbguerrajr
Is this what you mean?
I made my "knobs" from old switch levers, cut down and drilled to take the stalks. I'm told that this is what the originals were like.
1965 Elan S2 (26/4726)
2002 Elise S2 (now sold )
1970 Scimitar GTE
1970 Scimitar GTE
- Geoffers71
My 1963 1600 (S1) was not equiped with the interior lock latch rod - 'tho the hole is in the door trim to accommodate it. It has to be locked with the key from outside. That is the way it was built.
My 1965 S2 has the latch mechanism. the plastic knob is similar to that of the turn signal.
Bill
Bill
Bill Rathlef
Vancouver Island, Canada
Bill - Fourth Gear
thanks for all the replies, I'll check to see if I have suitable old switch lever to try out.
I'll be up in the shed tomorrow and will look the 26R as its been a while since I've been in the car, I know that I have no keys on the door locks.
I've made the eyebolts for a S2 I restored that is now owned by a friend in Sydney, I'll have a look at my note to see what I sourced the bits from, they may have been from a stainless railing supplier and it was used to ensure the wires kept their spacing if stepped on. I'll find some and put a photo up.
V
V
- vstibbard
