Folding rear seat squab
• Page 2 of 3 • 1, 2, 3
I have the folding rear seat on my +2 as well, and the remnants of the straps. I cannot see where they connected to, as there are no fasteners on the parcel shelf. Does someone have a picture of the parcel shelf with the fasteners installed?
Dave Chapman
Dave Chapman
- david.g.chapman
Dave
I've just ordered these Tenax fasteners from ebay - they are available in loads of places, these were cheapest I found, though I didn't shop around for very long.
http://www.ebay.co.uk/itm/140650581215_ ... EBIDX%3AIT
Martyn
Martyn
- martynw
david.g.chapman wrote:I have the folding rear seat on my +2 as well, and the remnants of the straps. I cannot see where they connected to, as there are no fasteners on the parcel shelf. Does someone have a picture of the parcel shelf with the fasteners installed?
Dave Chapman
My 1970 +2S still has everything in place (looks to be original). I'll take some pictures tonight.
Rob.
draenog - Third Gear
As usual, one job leads to another, so now I know how to attach my seat squab to the parcel shelf, I've realised that will just pull the parcel shelf out as it isn't fixed in place.
As the parcel shelf was a bit of a mess anyway, I'm making a new one using the old one as a template, however what is fitted looks quite different to the other pictures on this forum and in the book. I'm not sure if I have a homemade version, or if the +2S one was a little different to account for the folding seat, but as I am making one from scratch, I thought I might as well get it right.
Other parcel shelves have two lengths of steel angle - one near the front mounted on the top, and a shorter one further back on the underneath (like on this thread lotus-chassis-f36/recovering-parcel-shelf-t29366.html) I think there are two holes in front of the top channel which allow you to attach the shelf to the metal brackets above the petrol tank. These would then be covered when the seat is fitted (or in a +2S, when it is folded up).
My parcel shelf (below) has two lengths of steel angle, but both are mounted under the shelf. The front one is flush to the front edge. Before I stripped it off, this was wrapped in vinyl, but there are no holes to attach it to the brackets, meaning the whole thing just slipped forward.
Any +2S owners able to throw some light on how it should be? And if I need the top channel, could someone post the dimensions?
Many thanks again.
Many thanks again.
- martynw
My +2S shelf is identical to yours with both steel angle pieces on the bottom and nothing but vinyl on top. Unfortunately mine has been out so long that I can't be much help on how it's fastened in place. I apparently didn't take a photo during demolition, er disassembly. Hopefully someone will post a photo that can help us both in that regard.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Thanks Bud - quite glad it looks like I won't have to try and find some unusual shaped steel section for the top and can just use what I've got.
I'm also trying to work out if the vinyl folds around the steel to cover it up, or folds sharply back on the wooden shelf, so that the steel scures it in place once it is riveted. I'd have to paint the steel then, but as it would usually be covered by the seat, it should be fine.
I was expecting to find a couple of holes in the steel through which it would be easy enough secure it, but the fact that none were there made me wonder if I had missed something.
- martynw
On my +2S/130 the parcel shelf looked the same. From memory the vinyl was wrapped around the front metal piece and secured on the rear.
On the +2/130 there should be studs fastened to the top of the seat that slot down though the parcel shelf and into hold on the brackets. Can't seeing it being much different for the earlier setup but you never know....
- mbell
The vinyl on mine wrapped around the front steel angle and was cemented to the back side. If you need the dimensions for the stud placement I can help with that.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Apart from the two studs to retain the seat back, are there any other screws which hold the parcel shelf in place?
Breezehill - Second Gear
You need the 2 flat clips that go into the rear window rubber to support the rear of the shelf.
- alan.barker
Also there are two sheet metal screws with countersunk heads slipped through finishing washers, all in black, that attach the front edge of the parcel shelf to metal tabs underneath. Their location is very close to the studs for the seatback straps.
Can attach pix if you'd like . . .
The clips are across the lower edge of the window, however not sure if there should be other fasteners that go into the strut cross brace.
Here below find attached pix from my car (Feb 1970 Plus 2S) and from the Factory Workshop Manual (which in the Body section, has a paragraph dedicated to the removal and reinstallation of the parcel tray) . . . .
"Remove two screws securing front edge"
Funny (or typical?) that the location of the two mounting screws is just about far enough forward to be concealed by the overhang of the seatback . . . but not quite
That's the factory position for them (on MY car . . . not sure where the factory drill placed them on other cars!)
