Windscreen Problem
• Page 1 of 4 • 1, 2, 3, 4
A professional windscreen fitter came out tis morning to fit my new rubber and new windscreen glass to my S4 DHC. After at least 1 hour of perseverance he had to admit defeat.
He just couldn't get the screen to fit inside the rubber without the danger of over stressing the glass and potentially cracking it and he certainly new all the tricks of the trade. He couldn't be certain what part was causing the problem but as an idea he suggested I might like to try and source a second hand rubber surround to be sure of a correct fit and it would be more pliable. Both my new items were sourced from a well known UK Lotus supplier and the windscreen fitter had 35 years experience including lots of Elans. Not sure how to solve this one!! Any of you guys had a similar issue?
- William2
William2 wrote:A professional windscreen fitter came out tis morning to fit my new rubber and new windscreen glass to my S4 DHC. After at least 1 hour of perseverance he had to admit defeat.
Yep, My new Rubber was very stiff but 20 mins in boiling water it was soft and malleable. Buying a used seal could be difficult as they tend to go hard and crack when the screen is removed.
Out of interest, Where did you buy the seal from? Mine was a Sjsportscar seal, was a bit heavy on price but fit the windscreen aperture quite tightly with the corners in the correct place.
Grizzly - Coveted Fifth Gear
Are you sure you have the correct piece of glass. The S1-S2 glass is different from the S3-S4. I've never compared the two types, although I had one of each a year ago, but not today.
I am going to need new rubbers for my FHC I'm restoring. Has anyone been able to compare fit and quality between any of the suppliers available to us on this side of the pond?
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
This is my newly fitted screen,fitted by Miles.
The bodyshop that is doing my paintwork was pretty horrified by the fit of the rubber!
- Oldthumper
Yes Chris,the other corner is just the same.My bodyshop say not to worry,as the screens are coming out again anyway,and they say they will do it properly!
- Oldthumper
Gentlemen and other interested parties,
Problem is that the rubberchannel is joined at 90dg. angles. ( should be 105 dg. to memory )
According to Roy at PMS I was the first customer to notice this and that they had been like this for years. Dealing with PM for YEARS I am confident that this problem has been adressed by now.
Please expand a little on the screen with an incorrect curvature.
The best from Claus Garde in Denmark.
- c.garde
Here is the corner of my screen. The rubber was bought from Matty's last year and it fitted well. The angles seem to be right. The screen was supplied and fitted by National Windscreens last winter. The whole job took two guys just an hour.
TroonSprint - Fourth Gear
Looks like an excellent job with the wrong part..
When I brought home a new frontscreen a year ago I also bought a new seal.
Fitting this it looked very much as on pics of restored cars. of recent years: Hopeless at the bottom corners.
As I had on the shelves a new seal ( unused ) 20 years of age I chose to use this, and ofcourse I took measurements of the angles. So when I state that the proper angle must be around 105 dg. that is a statement of fact as any og you will be able to verify when changing an old front screen.
Best
Claus Garde
Best
Claus Garde
- c.garde
Isn't at least part of the problem here (with Grizzly's screen) that the filler strip is not cut & jointed in the corner? (as is troonsprints...)
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Don't know if it helps but this is a couple of pictures of how mine was when i got it (never been removed)
c.garde, seems you are correct. Just had a look at a few restored Elans and they all have ill fitting screen rubbers, looking at my picture's there is quite a difference in the corner angle (quite obviously not 90 degree's)
It seems that windscreens and rubber surrounds are a bit of a minefield!! I have been phoning around and found 2 windscreen fitters that I can call on to have a go if I get stuck. I will try and speak to Miles first and see what he reckons. I quite see the point that the rubber is not manufactured to the correct angle in the bottom corners to match the framework which doesn't really help the fitting process. I can also see the logic in mitring the filler strip in the corners to prevent having to bend. Not a problem on the S1 or S2. I feel it unlikely that the new Pilkington screen itself would be at fault.
- William2
I can vouch for the Pilkington screen (after my Ricky Racing saga i laid my new screen on top of the original one and it was identical, even the logo is in the same place), ironically with this subject coming up i had a look at my new seal and noticed its started to split from the corner seam, now i know its a 105degree frame and screen with a 90 degree rubber it isn't really a surprise the corner joint is starting to go.
I wish these aftermarket seal suppliers would get there act together, if it isn't the Door seals it the windscreen now
