Fixing LOTUS bootlid letters - measurements
I need to fix boot letters on my 1967 Plus 2 and will be holding in place with silicone sealant (as per advice in early discussions).
There are currently no hole in the boot so I do not know where to fix each letter - can anyone please post measurements of how far each letter is from the left edge of the bootlid?
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
David I had the same problem.
I had a green over white s4 with no lettering on the boot. Paul Matty has it for sale at the moment ant the lettering is still absent. Im sure I just googled for the information.
Sue miller has the letters if you need them
all the best
Stuart
all the best
Stuart
Europatc - Third Gear
I'm sure I've done this before but can't find it in the search function,so...
If your boot lid is 1080 mm wide,my letters centre at L 100mm,O 323mm,T 545mm,U 768mm,S 990mm
and left hand edge of letters are at L 95mm,O 317mm,T 538mm, U 762mm, S 983mm
and to finish it off their base line is 22 to 23mm from the lower edge of the boot/trunk lid.
Perfect, thanks.
David
David
David Rose
1965 S2
1966 S3
1965 S2
1966 S3
- dunclentdr
Correct me if I'm wrong but the OP asked for a plus 2? John - I thought you had a S4?
'72 Sprint
'72 Sprint
- richardcox_lotus
Correct me if I'm wrong but in the log book it states 50/0813 and since 1998 it does appear to have an extra couple of seats ( albeit rather small ) to the rear.....
Yet another bottle of red....
Coat....get....me....I'll.
'72 Sprint
'72 Sprint
- richardcox_lotus
If anyone is doing a paint job they can make you a template with masking tape.... Anyone???
Thanks Randy - yes, going to measure up over the next few days using John's information, if I get stuck will re-post!!
David
David
David Rose
1965 S2
1966 S3
1965 S2
1966 S3
- dunclentdr
My boot (Elan S4) is 40" at the top and 37 1/2" at the lip. So I'm hoping someone else out there with this ...
- Gettyselan
