REAR STRUT CROSS BRACE
PostPost by: AlfaLofa » Sun Aug 11, 2013 12:39 pm
Which series of cars had these braces and how are they attached to the chassis?
I saw an Oldelanman posting here:
elan-mods-f31/battery-cut-off-switch-t27407.html
which shows a battery isolator attached to one of these braces.
Presumably cars with the braces all have removable rear panels (unlike my S1)?
(Following picture copied from SJSportscars website)
SJ036A0001.jpg and
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa
PostPost by: billwill » Sun Aug 11, 2013 3:29 pm
My 1967 S3 Coupe has a brace like that, to which the rear panel of the cockpit is attached.
Not really removable as the carpeting is contiguous.
PostPost by: oldelanman » Sun Aug 11, 2013 4:49 pm
According to the parts list on the RD Enterprises site the brace was fitted from S3 onwards. It fits on the inside of the body using the two body mount bolts which screw into the rear towers.
Cockpit backboard 006.jpg and
S4 DHC
PostPost by: AlfaLofa » Mon Aug 12, 2013 2:20 pm
Thanks for the info. and the photo.
So the brace appears to make use of the Type26 seatbelt mounting points.
Presumably all cars fitted with the brace as standard used different seat belt attachment points?
Interesting - it's given me an idea (only an idea) for mounting a second speaker on my back panel without having to drill any extra holes.
AlfaLofa
PostPost by: oldelanman » Mon Aug 12, 2013 3:41 pm
AlfaLofa wrote:Presumably all cars fitted with the brace as standard used different seat belt attachment points?
That's correct the seat belt mount is further outboard on an outrigger bracket which fits under (or maybe over, I can't remember) the suspension top mount.
Seat belt mounting plates.JPG and
Seat belt mounting brackets
Seat belt top mount 003.jpg and
S4 DHC
