S1, 1.5 or 2 RHD glove box
PostPost by: Tahoe » Tue Aug 28, 2012 6:09 pm
I need a pattern for a RHD glove box S1 or S2 (not early S1 fiberglass). LHD is available here in the states but not RHD in my search. Anyway if someone has dimensions I'd like to make one up for myself. Maybe a LHD box is the same just reversed. Even LHD dimensions will work and I can reverse them and test fit for clearance issues if their are any..
Tahoe
PostPost by: nomad » Tue Aug 28, 2012 9:32 pm
Can't help except that I believe they are available. You are talking the hardboard box aren't you?
I'm looking for the LHD S1 box or some kind soul to let me take a mold off of one! ( Do I hear laughter?)
Kurt.
nomad
PostPost by: Tahoe » Tue Aug 28, 2012 10:29 pm
Nomad,
The LHD drives are available but I couldn't find a supplier in the US that had RHD available. Special order yes, but before I do that, I figured it couldn't be too dificult to make my own and a pattern would be helpful. I was thinking of making it out of Aluminum but fiberboard would be nice. The fiberglass ones are available from Tony Thomson. At least he lists them in his price list. Do a Google search for Tony Thmson Racing Price List and you'll get a .pdf.
Tahoe
PostPost by: nomad » Wed Aug 29, 2012 3:41 am
Thanks Russ, I'd heard that the RHD ones were available from Susan Miller but not the LHD. I'll check out Tony Thomson.
Aren't the hard board boxes available from RD?
Kurt.
nomad
PostPost by: ElanSeries2 » Wed Aug 29, 2012 9:08 am
Russ
I have one sitting in front of me, but it isn't easy to see how to describe/measure it without a lot of photos - its a complex shape, with 8 facets not including the (open) front. It could take some time to draw up, but if you really want the dimensions, I can do it. Let me know...
1965 Elan S2
1972 Elan +2S 130
ElanSeries2
PostPost by: Tahoe » Wed Aug 29, 2012 4:50 pm
nomad wrote:Aren't the hard board boxes available from RD?
Kurt.
Only in LHD from RD but it can be ordered. By the way Tony Thomson probably only makes it in RHD, but it's worth asking them.
ElanSeries2 wrote:Russ
I'd really like the dimensions, but not if it's a lot of trouble. Could you photograph each side with a ruler next to it? The dimensions don't have to be perfect as long as I can have some overall dimensions I can make something work.
Tahoe
PostPost by: ElanSeries2 » Wed Aug 29, 2012 6:01 pm
I will see if this one uploads successfully...
Bottom of glove box 1s.jpg and
1965 Elan S2
1972 Elan +2S 130
ElanSeries2
PostPost by: types26/36 » Wed Aug 29, 2012 6:14 pm
Deleated
types26/36
PostPost by: ElanSeries2 » Wed Aug 29, 2012 6:44 pm
Thanks, but I think I'm finally there! Although looking at my photos, I'm no David Bailey...
Top of glove box.JPG and
Outside of glove box 1.JPG and
Outside and bottom of glove box.JPG and
Front and top of glove box s.jpg and
Bottom of glove box 3s.jpg and
1965 Elan S2
1972 Elan +2S 130
ElanSeries2
PostPost by: Tahoe » Wed Aug 29, 2012 7:22 pm
Perfect, thanks very much!
Tahoe
PostPost by: LoTex » Sun Sep 02, 2012 5:50 pm
This is a useful subject. I've got an original hardboard box that has certainly seen better days but is still in one usable piece, the problem I have is that the glove box door does not fit snugly, there is 1/4" play at the latch, and the box has a tendency to shift backwards after a few miles of start and stop driving, the braces that hold it up are also not snug. Anyone else have this problem?
1965 Elan S2 #4226
LoTex
PostPost by: mac5777 » Mon Sep 03, 2012 4:22 am
Steve, send a picture, I've worked on a couple style doors and latches. Maybe I can help with your door fit.
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
mac5777
PostPost by: Matt Elan » Mon Sep 03, 2012 1:37 pm
I believe I've read somewhere that the fibreboard glovebox is a Triumph Hearld one.....
Visit me on matthewvale.com
Matt Elan
PostPost by: LoTex » Tue Sep 04, 2012 6:44 pm
Sarto,
Hopefully these photos are alright. Please note that glove box door does not fit flush and and although the box itself is intact it is quite warped. It may be a problem with the lock rather than the box however, any advice would be great-
LoTex
PostPost by: Tahoe » Tue Sep 04, 2012 7:27 pm
Matt Elan wrote:I believe I've read somewhere that the fibreboard glovebox is a Triumph Hearld one.....
Looking at Google images it's not a match.
Tahoe
Next
Users browsing this forum: mar083 and 12 guests
