Under bonnet foam
I am having a hard time sourcing the foam for under the bonnet. Mine fell off recently (fortunately not while I was driving) . This is the foam piece that prevents air from traveling over the radiator, rather than through it whent the bonnet is cosed. I tried some local stores but none of them stock foam. Where can I get a suitable replacement?
Chris 72 +2 s130
Chris 72 +2 s130
72plus2 - Second Gear
In Australia you can find rubber supply shops that can supply all sorts of rubber straps, sheet, foam etc. That is where I normally source foam for radiator and closed cell neoprene foam to replace the fibre mat between chassis and body and nay other genric type of rubber I need. I would presume something simlar exists elsewhere in the world ?
The usual suspects stock the foam - Mattys, SJ Sportscars, Christopher Neil.
Hamish.
Hamish.
Hamish Coutts - Fourth Gear
