Dash wood: teak, walnut, mahogany?
Since Gary says we need to post more (see "Top 20 talkers" thread), I thought I'd start a good old-fashioned debate on the wood species used for the various Elan dashboards. That's bound to generate some traffic.
Brian Buckland says that S1's had oiled teak dashes, the remaining series all used "polished walnut." Some posts said mahogany for the later cars. I looked through old posts and found neither a debate nor any consensus. I am planning to get a new dash built by C&G Woodcraft, and Gary (of that company) thinks that S4 dashes use teak. (I don't know his basis for that belief, however.)
Any takers?
Any takers?
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
I am having a mahogany dash built for my '70 S4 as that most closely matches what came with the car originally. Once I receive it, I'll take pictures of each, old and new. Dan
From the 1971 Elan Sprint factory brochure:
"... a fine teak veneer facia ..."
It would have been the same for the S4, too.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
The S2 (26/4997) is origanal and the S2 SE (26/5447) I believe to be original, I don't think either are teak. The S1 is teak I think that the S2's were Walnut.
elan-f14/and-dash-trim-question-t18371-15.html
I have other original dashes if you want to send Gary the above link.
The S3 right hand drive dash is not teak, I would need to look at it more carefully to see what "I think" it is. Mark I hope will be along to comment on this. He has a good grasp of what is and what isn't. I don't think any reproduction is a bad thing and in the U.S. will add value to any Elan. What ever you like you should do as its your Elan and you are the one that is going to live with it. Andy, I don't think you are going to sell it EVER judging by how long you have owned it.
Gary
Gary
Based on what I have run across in my cars - I would vote for all three woods being used depending on what was in stock or overstocked ...
this is the variety I have run across in my own cars -
s1's 63-64 - teak oil finish , 2 piece dash
s1 64 late walnut varnished , single piece
67/68 s1a & s1b type 46 europa's mahogany varnished ( I recall the s3 having mahogany but have never owned one)
George
George
- cabc26b
Hello from a taker.
My S1 has an original primitive teak plywood dash.
I have another original spare S1 dash, separate glove box design, and it is of a most beautiful unknown wood. I'll try and post a picture. It has the little plastic trim pieces tacked on the bottom edges. Totally different from my Elan's dash...
Eric
Eric
- 1964 S1
As not a massive fan of the originality team I would be going with whatever looks the best in your car. There seems to be fair reason to believe that the timber changed over the years so unless a concours car why not go with something you like - personally the oiled ones always look tatty to me.
Gordon
26/5416
26/5416
- gordont
I bought my ?lan in January 1980 and the PO had repaired it after a fire. The cowl fiberglass, wire harness and fascia were replaced (and many other small parts). The PO said that the fascia came from Lotus (it's cracked enough to make me believe it!); one of the last replacement parts available. I've tried to match it with veneer samples on the internet, but can't seem to find a match. The closest I've found is quartersawn Cherry ( http://www.formwood.com/CherryQuarteredVeneer.html ). It looks different from the other fascias I've seen. The radio hole plug came from a TC Europa and does not match.
1969 Elan S4
1700 cc, Dave Bean #112 cams.
Union Jack Exotics
Union Jack Exotics
dlbutler - Second Gear
dlbutler wrote:I bought my ?lan in January 1980 and the PO had repaired it after a fire. The cowl fiberglass, wire harness and fascia were replaced (and many other small parts). The PO said that the fascia came from Lotus (it's cracked enough to make me believe it!); one of the last replacement parts available. I've tried to match it with veneer samples on the internet, but can't seem to find a match. The closest I've found is quartersawn Cherry ( http://www.formwood.com/CherryQuarteredVeneer.html ). It looks different from the other fascias I've seen. The radio hole plug came from a TC Europa and does not match.
Both my 68 S4SE and 72 Sprint were/are exactly the same plywood as in your photos (not the radio blank, which looks different). The only walnut ones I've discussed with owners have been replacement items; I've always considered them a bit too "posh" for the Elan but more appropriate in the luxo-barge +2.
Pete.
http://www.petetaylor.org.uk
Pete.
My Elan is very original, including its dash. The photos below comparing my dash with the samples from http://www.formwood.com/veneerlibrary.html suggest that it is either teak or afromosia. Most books I have read suggest that the baby Elans came with teak and that only the +2's were fitted with walnut by the factory.
An interesting twist is that the grain in mine runs vertically.....
- Attachments
- teak_qrtd3.jpg (32.38 KiB) Viewed 3599 times
- afromosia3.jpg (31.59 KiB) Viewed 3598 times
Evan J
Elan S4 FHC RHD 36/8569 AND White Evora S..
RedS4 - Third Gear
My '67 S3 dhc bought in '72 has dash identified by wood guys as mahogany--the main issue is that the Elan had straight grain wood dash; then my 72 +2S130 has burl and it is walnut. The '67 was not oiled but the nice, crackable thick lacquar that was apparently used. Gordon Sauer
- Gordon Sauer
RedS4 wrote:My Elan is very original, including its dash. The photos below comparing my dash with the samples from http://www.formwood.com/veneerlibrary.html suggest that it is either teak or afromosia. Most books I have read suggest that the baby Elans came with teak and that only the +2's were fitted with walnut by the factory.
Really? First Elan that I have ever seen with "original" grain running upwards. 40 years on, one still lives and learns.
Pete.
Pete.
I would go to a good furnituremaker or someone who makes boet interiors to have the das rebuilt or renovated.
Often the lacquer tends to get a slightly different colour over time, so that will have effect on what a dashboard looks like after roughly 50 years.
The question is if you want to have a almost original, reproduced dashboard with the original colour or if you want to have a dashboard that has the same appearance as the old one, meaning that the colour has changed.
I, for one, IF needed, would go for a reproduction of the original dashboard, hence taking the different (original) colour for granted.
J
J
"Make the suspension adjustable and they will adjust it wrong - look at what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver..." (CABC)
My one problem is that distance keeps me from my Elan. (36/5395)
Jens - Second Gear
elansprint71 wrote:Really? First Elan that I have ever seen with "original" grain running upwards. 40 years on, one still lives and learns.
I agree, I've never seen one and to be honest it looks a bit odd ..... no offence intended
Users browsing this forum: 661 and 10 guests
