Window motor runs backward
I had the driver's window motor cleaned and lubed by a shop
and now the window motor runs backwards. The switch up position
lowers the window and vice versa.
How do I reverse the motor? I borrowed a spare window motor that works
correctly and both have identical wiring.
TIA
Phil Mitchell San Jose CA.
TIA
- pamitchell
I had this problem on mine when I first re-installed the motors after lube and cleaning. I just turned the toggle switch over ... don't know if the polarity had changed or it was my error in reconnecting the wires to the motor and switch or if I just had the switch upside down to begin with.
-Marc '66 Elan DHC (36/6025)
http://www.lotuselan.us
- marcfuller
I too, had my drivers side switch working backwards after replacing cable. My mechanic had been working on the instruments and the dash and may have reinstalled the switch and reversed the wires. They fixed it. I don't remember if they just turned the toggle over or changed the wires. The easiest, like Marc, is to just flip it.
Sarto
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
36/5785
LHD
mac5777 - Fourth Gear
Thanks All for the advice.
How do I reverse the wiring on the motor?. I have 2 Green wires paired together with a bullet connector, 1 Black ground spade connection to the
motor housing. 1 Brown/Red tracer connects to a terminal in the red housing above the motor gearbox. There are two connectors marked Green & Black in the red housing. The Brown/Red connects to the Green terminal. Do I switch it to the other terminal in the red housing?
TIA
Phil
TIA
Phil
- pamitchell
Phil.
I had the same question about just changing the motor wiring. Mine, like yours just plug in. The dash switch wires would be the easier to switch. I just turned the toggle over.
Sarto
Did get the pictures of the leather grab socket?
Sarto
36/5785
LHD
36/5785
LHD
Users browsing this forum: smiths everest and 25 guests
