Bonnet stay.
Hello all.
Could anybody inform me were i could purchase a new telescopic bonnet stay for a 1969 +2s , spoken to Roy at PMS and he informed me that they were no longer available , was this type of bonnet stay used on other 1960s car.Only need to replace bonnet and MOT car and sould finally be finished .
regards Ian.
regards Ian.
- FEDUP
Ian, I purchased a Spitfire Boot stay. Exactly the same length (static and extended), holes etc. Only difference is the catch (self releases when lifted). If you're not happy with that aspect, I'm sure you could modify. I purchased mine in the UK from Winns.
Gerry
Ian, when I say Boot of course I mean trunk.
Gerry
- gerrym
Ian,
Have you tried Sue Miller?
- martinbrowning
Hi Fedup, i assume you want new as in replacement for old & not that you dont have one? For if you dont have one i know i have one somewhere if it will help. Regards Curly
- curly type 26
Ian,
keep an eye on Ebay, tragic though it is, people are frequently breaking +2s. They probably don't list the bonnet stay specifically so you may have to ask if the have one for sale.
- mikealdren
Jerry/Mike
Hi plans changed found original bonnet stay in loft so decided to use both original one on passenger side and spitfire self release on drivers side, had to weld additional 6mm nut on bonnet support bracket drill hole in inner wing in the correct position .
I will need to get them bright zinc coated in the furture but that will have to wait, sorting bonnet to cam cover clearence at the moment luckly i elongated the engine monting holes previously so just need to release off and drop engine a extra 3mm hopefully.
Booked in for MOT tomorrow morning last one 4 years ago.
Thanks for the information
Ian
Ian
- FEDUP
